01-23-2012, 04:39 PM
Member #22522
starting trouble
i have a 1999 sportsman 500 and when i try to start it the solenoid clicks and it has a brand new starter solenoid and battery cant figure it out thanks
01-23-2012, 05:08 PM
Member #22522
any suggestions
01-23-2012, 05:11 PM
Well, if the solenoid is new (and the clicking is good in regards to that part) and the battery is new, and we know the ignition is working since the solenoid is clicking, the only thing left is a bad starter motor. Probably worn brushes inside the starter.
01-23-2012, 05:15 PM
Member #22522
the sttarter is brand new to and i jumped it off my truck and it works the crazy thing is i can take the positive off the starter and get 12 volts on my meter but when i hook it back up to the stater the solenoid clicks
01-23-2012, 05:29 PM
You mean you take the red cable off of the starter and you get 12v on the end of that cable?
01-23-2012, 05:33 PM
Member #22522
yea the one that goes from solenoid to starter
01-23-2012, 05:46 PM
I'm still suspect of the starter at this point. Is it a brand new OEM starter? How new?
Also, may be worthwhile load testing the battery. Volts isn't what the starter uses, it is amperage. May be the battery doesn't have the amperage to turn over the motor.
01-23-2012, 05:53 PM
Member #22522
its a brand new starter from db electrial just got it friday and i even hooked up jumping cables from my truck to battery n still just got clicking
01-29-2012, 05:33 PM
Member #22027
I got same problem, haven't tested anything. What should I troubleshoot? Mine did start fine when I bought it from a guy, then it would start to engage the starter and not complete, now it just clicks at the solenoid. It has a new battery. I have a multi-meter, what do I need to check?
01-29-2012, 06:27 PM
Member #11816
check for loose wires mine was doing that not too long ago and the battery wire were loose tighten them up and bam also check for corrision if it is use any sand paper to fix that really and check wires going from battery to solenoid to starter oh and btw the guy is it from a guy off ebay selling starters for 45 bucks with free shipping
2001 Polaris sportsman 400 4x4 olive/ sage green
polaris trouble starting, starter bendix sportsman 800
