Old 01-24-2012, 06:13 PM
Dempsey92's Avatar
Member #22344
2005 sportsman 700 clutch and trans questions
I bought a 2005 sportsman 700 with gorilla lift and 29.5s. It has a clutch kit in it with a stall but the primary clutch is cracked bad will a older sportsman clutch fit it like off of a 2000 model. And about transmission It only has low neutral and reverse the guy said it has gear reduction Does gear reduction do away with high and park. The bike only does like 20 mph
Old 01-24-2012, 06:20 PM
2005 polaris 700 clutch
2005 polaris 700 clutch kit
2005 polaris sportsman 700 clutch
2005 polaris sportsman 700 clutch kit
2005 polaris sportsman 700 clutching
clutch kit 2005 sportsman 700
polaris sportsman 700 rear clutch
sportsman cracked clutch
what clutches will fit a 600 sportsman
Sportsman 500 Clutch Spring and Puller questions factionfx ATV Performance Modifications 10 02-18-2012 08:07 PM
2005 Sportsman 700 EFI questions crankin ATV General Discussion 4 08-01-2011 05:37 PM
97 scrambler trans questions! 97polaris500 Polaris Scrambler 0 05-13-2011 11:20 AM
Questions on 2005 400 Sportsman NJTrapper ATV New Members 2 01-30-2011 08:32 AM
2005 Polaris Sportsman 400 wheel bearing questions? tcj198 ATV Repair and Maintenance 0 10-07-2010 02:14 PM
