01-25-2012, 10:01 AM
Member #22590
Sportsman 500 No Spark
Hi, guys. Need a little help. Working on my friends 2001 Sportsman 500 HO. It has no spark. Here's what I have done: disconnected the black wire from the CDI unit - still no spark. So i started to test the wiring. Put my volt meter on the white and white/red wires from the trigger coil. While cranking the engine, I did not see any voltage on the wires (AC or DC). I then ohmed out the two wires and got about 95 ohms between the wires. I couldnt find a three wire connector going into the CDI but I did find a two wire connector which was red and I think black. Ohmed these out and got 9.5 ohms. Nothing was shorted to ground. Checked all the connections and they looked good. My question is should there be any voltage on the W/R to W wires while cranking? Is there any other tests I can do without pulling the side cover and flywheel off? Also....the pull rope is broke off but was running after that for awhile. Please help! I get a mini-chopper if I get his Sportsman running! Ha, Ha! Thanks a bunch!
01-25-2012, 04:52 PM
01-25-2012, 06:19 PM
Member #22590
Thanks, Bruce. Know any stator experts?
01-26-2012, 03:08 AM
Member #20904
Ricky Stator in CA is good, I bought one from him and he gave me all kinds of info as to what to look for and the correct way to install it.
01-26-2012, 07:21 AM
Member #22590
Thanks for your help. I am having trouble downloading the service manual that is here on the site.  All I get is the downloader program. Can one of you guys send me a copy of the manual for this 2001 Sportsman 500 HO? I'll buy you a beer! LOL!
Thanks!
01-26-2012, 06:16 PM
Member #22590
The wiring from the stator seems to check out per the specs. I noticed tonight that when I turn the ignition on and try to start the engine.......I get one spark at the plug then nothing!!???  Any ideas?
Thanks!
01-27-2012, 03:12 AM
Member #10305
if I recall right, I had one that did this and I want to say it was the ignition switch
01-28-2012, 05:20 PM
Member #22590
Ok guys.....I fixed it! Pulled off the side cover to check out the stator and found that a piece of the broken pull rope had smashed into the pickup coil and bent it back away from the flywheel. I was able to straighten it back up, wallowed out the mounting holes for adjustments and remounted with a dollar bill for the gap adjustment! Worked like a champ! Runs super now with no missing or backfires! Hope this helps someone else!
Thanks!
2012 polaris no spark, 96 polaris sportsman 500 has no spark, 96 polaris sportsman no spark, cranking voltage 90 polaris sportsman, how do you test 2001 sportsman 500 cdi, how to check a cdi unit on a sportsman 500, how to check for week spark polaris 400 sportsman, polaris 500 no spark, polaris sportsman 500 has no spark, polaris sportsman 500 no spark, polaris sportsman 500 no spark ignition, polaris sportsman no spark, polaris sportsman problems, polaris sportsman runs then no spark, polaris sportsman weak spark, polars sportsman 500 no spark\, sportsman 500 mo spark, sportsman 500 no spark, sportsman 500/no spark, sportsman500 no spark
