01-25-2012, 10:39 AM
Member #22647
Winch cable rubbing on front brushguard when using snow plow
I have a 2008 Sportsman Touring with Polaris Brushguards and a Polaris winch, I recently bought a snow plow from Polaris (Glacier III) and a 52 inches blade. My problem is the following: the winch cable is rubbing against the horizontal tubing of my brushguard. Did anyone encountered this problem and if you did what was your solution?
01-25-2012, 11:18 AM
Member #14376
01-25-2012, 12:55 PM
Member #22647
After I had it installed I tought that I would have been better with another brand of blade/installation but it looks that you have the same problem with a Cycle country plow. I think it is a great idea that you had. You mentioned that the piece of mud flap is made of ''real rubber'' something like we see or tractor trailer or the usual car mud flap which are made of plastic/rubber? Thanks a lot.
01-25-2012, 01:13 PM
Member #19703
just a thought, my glacier 2 DOESNT rub, im pretty sure because polaris was selling "extended" plow frames for the x2s and tourings....
the only reason i put material on mine (instead of rubber) is because it rubs when i try to LIFT something or PULL something out of the ground....
doesnt have to be rubber really, it can be a piece of garden hose, jeans cloth,
or a piece of soft-ish plastic...
hope i helped.
2007 800EFI X2 Deluxe
-polaris 2500# winch
-tool grips
-VIP air windshield
-safety flag (polaris)
-Glacier II plow system
-front hitch
-1700KM
2010 850 XP EPS
- 2500# polaris winch
- VIP air windshield
-498KM
01-25-2012, 01:45 PM
Member #11566
I have a 2008 800 and I have the same issue. I bought a Warn front mount plow this season and only used it a couple of times. I have the synthetic rope and it just rides on the cross tube. There is a little wear on the power coat, but it looks like it will take quite a bit of use before any real wear.
01-25-2012, 03:06 PM
Member #20347
Same thing happened with mine....i took an old piece of really really thin tin that was a tube for an exuast for a chimney...i cut a section out and placed 2 hose clamps on it. Works like a charm
01-25-2012, 03:37 PM
Member #22647
It is amazing that a company does not offer a solution to a problem that seems to cause trouble to Polaris owners since few years. I have sent an e-mail to Polaris and they refer me to my dealership. The problem is not the installation but a poor design and making sure that all their products can be used together without causing problem. I think in the future I will rely on aftermarket products instead of "Pure Polaris".
01-25-2012, 04:27 PM
Member #11247
Polaris Sportsman Brush Guard Winch Cable Protector | eBay
Polaris part number 2859089
There are a few threads in here about it already.
2011 Trail Boss - HIDs SOLD
01-25-2012, 04:30 PM
Member #22647
I have found that number and searched Polaris site but there is no such thing.
01-25-2012, 10:58 PM
Member #11247
I don't believe they make them anymore because they don't make that style ATV anymore. You might be able to get one from a retailer who still has one.
2012 atv front brush gaurd, atv snow plow cable wear, cable rub rubber, powered by vbulletin snow shoe, rub guard for polaris sportsman brushguard, rubb brush for cable, rubber cable guard atv winch, tractor trailer thin rubber mud flaps, will polaris snow plows fit all sportsman models
