01-25-2012, 06:14 PM
Member #21883
where to buy ball joints and tie rod ends
Best place to buy parts for a 1998 sportsman and 2003 ranger 500 4x4? Looking for ball joints, tie rod ends, other parts.
01-25-2012, 06:18 PM
Member #3687
All balls brand of tie rod ends are good. The tie rod kit will include 1 outer and 1 inner tie rod end. They might make ball joints also.
01-25-2012, 07:03 PM
Member #15984
They certainly do make ball joints. I replaced mine with All balls brand last summer. No problems so far but they are not greaseable. But then I don't think any aftermarket brand is. I got mine on ebay.
01-26-2012, 09:25 AM
Member #14887
Check with cycle parts warehouse dot com, they have real good prices.
I actually just purchased some ball joints from "All Balls" off ebay and waiting there arrival...
Kevin
01-31-2012, 08:42 AM
Member #9660
I replaced the tie rod ends on my Sportsman 450 about 8 or 9 months ago. They seem to be holding up just fine so far. I got mine off ebay as well. I believe it was around 50 bucks for two pairs.
01-31-2012, 07:00 PM
Member #15640
Pull your boots on your tie rod ends away a tad and squirt some Lithium grease into them, they'll last longer. You can't buy greasable ball joints anymore even if you go OEM, way to go Polaris, the ball joints are the lowest part of your front suspension and you should be able to grease them.
02-01-2012, 06:21 AM
Member #8717
Just out of curiosity, what symptoms does it show when these parts wear?
02-01-2012, 06:21 PM
Member #14887
Lift the front end on a block, grab the top and bottom of your tire and try to rock it toward and away from you from the bottom. If you feel play , it's a worn ball joint. They will last till they break but cause uneven tire wear and loose feeling steering etc...
Kevin
04 polaris sportsman 400 4x4 all 4 tie rod ends, 07 polaris ranger inner tie rod, 2003 polaris 500 ball joint ends, 2003 polaris ranger tie rod, 2011 ranger 800 xp oem inner tie rod, aftermarket tie rod ends for polaris sportsman, all balls inner tie rod end polaris, ball joints, polaris ranger 2003, greasable ball joints and tie rods, inner tie rod for polaris 700 sportsman, inner tie rods 2003 polaris ranger, polaris atv 4x4 balljoint parts, polaris atv tie rod ends, replacing ball joint on polaris ranger, rod end hr for atv, rod end hr for atvs, sportsman 700 tie rod, tie rod ends for 2012 polaris ranger 500, where to buy bal joints, where to buy ball joint rod ends
