01-27-2012, 06:54 AM
Member #22707
05 Polaris Sportsman 700 - Broken inner clutch
Well, I was taking off the clutch so I could repalce my starter and broke a chip off the inside clutch. It is about half of a quarter. I am guessing this will eventually rip up my belt.
Anyone have any idea if I can but just the inside part of the clutch without having to but the whole clutch?
Also, any idea if the inner clutch on a 500 and a 700 are the same size and can be changed?
I may be able to get a used clutch for a 500.
01-27-2012, 06:56 AM
01-27-2012, 11:57 AM
Member #14887
Post a pic of the broken part please.
Most parts can be replaced on this clutch. Not sure if the 500 and 700 clutch are the same. Call your dealer to be sure.
If they look similar , you should be Ok. Maybe the 700 has a heavier stock clutch spring, you can always change that.
Kevin
01-27-2012, 02:44 PM
Member #22707
If I get the inside clutch part can I put it on the clutch I have?
01-27-2012, 04:44 PM
Member #14887
Depends what it is , show us a picture of the damage...
Kevin
05 polaris sportsman 700, 05 polaris sportsman 700 clutch drive assembly, 05 polaris sportsman 700 drive clutch assembly, broken clutch atv, clutch for polaris sportsman 700, clutch problems for an 05 polaris 800, how to change belt on polaris sportsman 700, polaris 700 drive clutch, polaris clutch broke, polaris sportman 700 broken belt, polaris sportsman 2011 primary clutch cracked, polaris sportsman 450 cracked clutch, polaris sportsman 700 clutch, polaris sportsman 700 clutch drive swap, polaris sportsman 700 clutch issues, polaris sportsman 700 drive belt, polaris sportsman 700 drive clutch, repair polaris 700 driven clutch, replace the clutch 700 polaris, sportsman 700 cracked clutch
