99 500 non/HO spark/starting issues
Just picked up this bike up off Craigslist. It's in pretty good shape, just has been sitting for a while. Needs the brakes freed up and gone through, got the front master cylinder cleaned up and working. Rear brake works.
Put a new starter, carb, and battery in it, and cranks over, just no spark with the timing light. Put the timing light on the primary wire from the coil to the Cdi box the light shows fire. Checked out the coil, and it ohms out at the right ranges. .03 on primary side and 6400 on the secondary. I checked voltage from the CDi box and I want to say it was around .80 millivolts.
So, now I'm thinking the stator is bad so I checked the ohms on it and they are close to the specs but there is a little more resistance than there's supposed to be. Would it not be letting it build up enough voltage to send to the Cdi box and coil?
What else is there to check that I overlooked? I did clean the flywheel of rust for the pickup also.
Thanks in Advance,
Aaron
Reason: Forgot
