Old 01-29-2012, 08:06 AM
mtuser2007's Avatar
Member #6192
Sportsman X2 700 Stuck in Reverse in a Field
I was driving my Sportsman X2 700 in a field when something happened. I had stopped, and was slowly reversing. I went to go forward and I can't move the shift lever. The back wheels were turning and I had to put my brake on to hold the vehicle. I turned it off. Now of course I can't start it because it is stuck in reverse.
Questions:
1. Any idea what has happened? Is the belt broken?
2. Is there anyway to pull a pin so I can try to push the ATV to someplace where I can load it up to get it home or to a repair shop?
3. Any other advice for me? I am new to ATV ownership so maybe I am not asking the right questions?
Old 01-29-2012, 02:32 PM
lost cause's Avatar
Member #9763
Just try rocking it while trying to shift it. Sometimes if there is pressure on the transmission it will be hard to shift. Just like if you park your car on a steep incline and don't use the e brake it will be hard to shift from park into gear.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-29-2012, 03:16 PM
NoJoke's Avatar
Member #19171
If the X2 is in gear you can start it by applying the hand brake.........good luck with the problem.
Old 01-29-2012, 03:22 PM
mtuser2007's Avatar
Member #6192
Thank you for this suggestion. I'll go out to the field and try it.
2008 X2 700, 2002 Sportsman 500
Old 01-29-2012, 03:23 PM
mtuser2007's Avatar
Member #6192
Thanks for this tip. As I am a newbie at ATVing, I was not aware of that.
Old 01-29-2012, 04:31 PM
did it start? or is it bound up still?
2008 polaris sportsman 700 x2 stuck in one wheel drive
2008 polaris spotsman gears stuck
2008 sportsman hard to shift
2008 sportsman shifting problem
2012 polaris crew stuck in reverse
2012 polaris sportsman 700 x2
how do you fix your quad if its stuck in reverse
my 2008 sportsman shifts hard
polaris 400 stuck in reverse
polaris atv shifting from park into gear is hard
polaris atv stuck in reverse
polaris quad stuck in reverse
polaris sp ortsman 400 stuck in reverse
polaris sportsman 700 stuck in drive
polaris sportsman reverse
polaris sportsman stuck in reverse
polaris sportsman x2 ammo can
polaris x2 700
sportsman x2
what to do if quad is stuck in reverse
2003 Sportsman 500 gets stuck in Reverse Thurman_Murman74 Polaris Sportsman 3 10-26-2011 03:30 PM
2001 400 Sportsman stuck in reverse DaveC ATV Repair and Maintenance 3 10-25-2011 07:06 PM
stock tires + corn field mud = STUCK ShadyOaks Polaris Sportsman 6 03-13-2011 07:57 PM
1999 sportsman 500 stuck in reverse towtrucker ATV Repair and Maintenance 5 02-28-2011 08:16 AM
02 500 sportsman ho stuck in reverse biker ATV Repair and Maintenance 1 01-09-2010 02:40 PM
