01-29-2012, 12:16 PM
Member #22767
2006 sportsman 500 efi
Hey there, just picked up a 2006 500 efi and have a few questions about it. I own a 2005 sportsman 400 as well and there seem to be some things different. for starters. the 2006 can be started in gear, is this normal? You also don't have to press down the foot break to shift into high or park? I have noticed that the plastic is starting to melt on the right side by the exhaust, pretty sure i can save and remount the plastic but need some ideas for stopping the melting. please give me some ideas guys! Glad to be here and looking forward to getting new ideas and sharing my knowledge on stuff with you guys too.
01-29-2012, 12:21 PM
Yes, starting in gear and not needing to press the foot brake is normal.
As far as melting plastic, 3M makes heat tape. You cut it to shape, and stick it to the inside of the plastics near the exhaust, and will deflect the heat away.
It likely had this heat tape before, but it may have been removed or deteriorated by now.
The 3M is good stuff though.
01-29-2012, 12:27 PM
Member #22767
thanks, the shifting just seemed odd to me. I will do the 3 m tape. thats what i was thinking but wasnt sure if it would hold up, good to know. Also on the display there is a wrench flashing. I am hoping that is for the oil change but is there anything else it could be. I know nothing about these efi models and this was a quick buy without much homework on it. the price just seemed really good and i needed another quad. is there anything i should look out for or need to know about the 2006 efi model?
01-29-2012, 01:23 PM
Member #17372
polaris makes heat shield kit you can buy its all bolt on, my buddies 06 had plastic melting and put the kit on and no more melting.
01-29-2012, 03:46 PM
Member #22767
any idea where to get that heat shield?
01-29-2012, 04:30 PM
the wrench is to let you know the hrs are up for service, you can re-set it to whatever hrs you want or turn it off , the owners manual tells how
01-30-2012, 04:10 AM
Member #17372
he got shield thru polaris at the dealer don't have the parts number. just ask for the heat shield update for 06 EFI and they should find it.
01-30-2012, 05:54 PM
Member #22767
thanks
06 polaris 500 efi cut out, 2006 polaris sportsman 500 cost, 2006 polaris sportsman 500 efi price, 2006 polaris sportsman 500 exhaust, 2006 polaris sportsman 500 value, 2006 polaris sportsman dual exhaust, 2006 sportsman 500 exhaust melting the plastics, 2006 vs 2012 sportsman 500, atv heat shield polaris sportsman 500, exhaust for 2006 polaris sportsman 500, exhaust heat shield for polaris sportsman 500 efi ho, for sale 2006 polaris sportsman 500, heat shield 2006 sportsman, polaris 2006 atv forum, polaris 450 melted plastic 2006 kit, polaris 500 exhaust melting plastics, polaris atv 2006 sportsman 500, polaris efi 500 cuts out, polaris exhaust melting plastic, polaris sportsman melting
