Old 01-29-2012, 08:53 PM
lasportsman3's Avatar
Member #22654
2011 Sportsman H.O. waterproofing
After a lot of trouble, I finally got my bike to quit stalling in deep water. My first go round water proofing it I half a**ed putting dielectric grease on my spark plug boot ( i didnt pull it out and i just used my finger to whipe the grease around it). It wouldn't idle under water and it would stall if i didnt stay on the throttle in a deep hole. Today I pulled out the boot, put a lot of dielectric grease on it, and put a screw in my carb drain hose. I took it to a little water hole behind my house and for the first time since Ive had my bike, it could idle under water. This is a short clip of testing it:
Old 01-29-2012, 09:13 PM
Meeks39's Avatar
Member #22794
Good deal, man. That must have been frustrating. Thanks for the tips.
Old 01-30-2012, 05:48 AM
lost cause's Avatar
Member #9763
Now you need to run your vent lines up and snorkle your intakes.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-30-2012, 07:34 AM
Member #22654
which vent lines do i need to run up on an '11? I didn't notice any important ones that didn't run up to my pod but i could have missed one. i'm going to hold off on snorkeling the intakes, i bought the 5 year warranty and i would not be happy if it got voided
Old 01-30-2012, 09:07 AM
lost cause's Avatar
Member #9763
Front and rear diffs and fuel tank are the main ones. I have not seen an 11 so not sure where they are run too, but if they are already in the pod then you are good. And just a note on the snorkels and warrenty, just remember that warranty does not cover a drowned out machine. Gotta way the pros and cons there if you like riding the water/mud.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 01-30-2012, 01:59 PM
SMP63's Avatar
Member #13545
Lost Cause is on the money!!! I had to reroute the front diff & tranny vent hoses to the light pod on both my wheelers!!!!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 01-30-2012, 02:35 PM
Member #22654
thanks i'll reroute those. if it looks to deep i stay out of it. the reason i did this waterproofing was because my bike was stalling in holes shallower than the one in the video
Old 01-30-2012, 05:45 PM
SMP63's Avatar
Member #13545
Originally Posted by lasportsman3 View Post
good deal thanks i'll reroute those. if it looks to deep i stay out of it. the reason i did this waterproofing was because my bike was stalling in holes shallower than the one in the video
Had the same problem with mine. Always remember "when in doubt back it out".
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
Old 01-31-2012, 10:22 AM
lost cause's Avatar
Member #9763
^^^ That's not right, "when in doubt, throttle out!!!" lol
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 01-31-2012, 12:31 PM
SMP63's Avatar
Member #13545
^^^^ For those of us that don't have your list of mods Lost Cause & try that, it usualy means "getting pulled out"!!!! LMAO!!!!!!
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
2010 polaris 500 ho dies in water
500 polaris ho dies out when u get in deep water
800 sportsman dies in deep water
differential vent size on sportsman 800
drowned polaris sportsman 850
how do i waterproof 2011 sportsman 500
polaris 500 waterproofing
polaris sportsman 400 hd drain water
polaris sportsman 500 in low gear for hills
polaris sportsman cutting out in water
sportsman 500 differential breather for water
sportsman 800
sportsman 800 best 14 inch wheels
sportsman 800 cuttin out under water
sportsman cutting out in deep water
water proofing a polaris
water proofing polaris outlaw 90
water proofing sportsman
waterproofing polaris 500
welded low gear sportsman
2011 Sportsman 500 replaced w/ 2011 Sportsman 800 EFI bulldawg87 ATV General Discussion 4 09-24-2011 03:41 AM
2011 550 sportsman xp eps OTD???? sykeadelic ATV Purchasing and Price 10 09-13-2011 04:43 AM
waterproofing 800touring ATV Performance Modifications 4 07-05-2011 03:29 PM
Rebates on Nearly all 2010 and 2011 Models March 1st, 2011 cmharcou ATV Purchasing and Price 0 03-02-2011 02:56 AM
waterproofing mjohnson ATV Performance Modifications 0 11-08-2009 09:55 AM
