Old 01-30-2012, 01:17 AM
Picpic's Avatar
Member #22123
Idle problem
Hi
I have som idle problems on my Polaris Sportsman 500 EFI 2007.
I start it up (cold) and it idles on correct rpm. Run it for 10 minutes and release the throtle. Engine speed goes down to about 1500 rpm and stays there for about 10-30 sec before it goes down to correct level. Sometimes it wont go down so i turn the key off and restart and then it idles correct. Sometimes when it goes down it idles on too low level so that the engine stops.
I have been running it with a lot of stop and start in cold weahter below freezing point the latest month.
Any ideas?
Jonas
Old 01-30-2012, 10:08 AM
500hoho's Avatar
Member #20938
Maybe a good throttle body cleaning may help or it could also be a tps sensor issue
how do i change the idle on my polaris sportsman 500 efi
idle problems polaris
idling isses polaris sportsman
polaris sportsman idle problem
polaris sportsman idol jumps
polaris-idle problem
problem with my polaris idle
Need Help with Idle Problem tjrockcrawler69 Polaris Sportsman 6 12-29-2011 04:57 AM
95 Xplorer Idle Problem DoctorV ATV Repair and Maintenance 3 12-16-2011 01:05 PM
Idle Problem Trapp Polaris Trail Boss 5 11-24-2011 08:55 AM
Problem with idle mix screw Natureboy Polaris Sportsman 10 08-15-2011 03:27 AM
Idle problem QuadCorey Polaris Scrambler 3 07-03-2011 08:12 AM
