Old 01-31-2012, 09:44 AM
sleded42's Avatar
Member #22855
2010 polaris 500 sportsman wont start
i have a 2010 sportsman with approx 500 miles on it. three times this winter i have had issues with starting it. it starts ok in the morning but then it starts to act up(sputtering, poping, backfiring) and wont run.Then it refuses to start. There is spark on the plug and theres fuel getting to the carb. Any help would be greatly appreciated.
Old 01-31-2012, 03:23 PM
Old 01-31-2012, 04:56 PM
water in gas? try running 1 oz of Seafom per gallon of gas and see if it clears up
Old 02-04-2012, 06:10 AM
sleded42's Avatar
Member #22855
I bought it to my local Polaris dealer. He drained the gas, changed the plug and the bike fired up perfect. I am considering Putin in a water separator. Will this solve my problem?
Old 02-08-2012, 04:02 PM
cxcmoto's Avatar
Member #19300
Send a message via AIM to cxcmoto
Better to store them with the tanks completely full. Air space allows for condensation. Also treat the gas with stabil and/or ethanol treatment.
Old 02-08-2012, 04:31 PM
where is it gettin the water? does it sit outside?, maybe where you buy your gas?
Old 02-08-2012, 05:51 PM
macka's Avatar
Member #23019
The heat off the engine heats the gas tank, and when it cools water droplets form inside the tank. Mostly happens in the winter and fall. Seafoam is the best IMO. It also cleans the carb and can be used before an oil change to help degunk the oil galleys and valve seats.
Old 02-09-2012, 01:16 PM
PolarisRich's Avatar
Member #7183
Exactly..
Condensation collects inside the tank from temperature differences between fuel and air! Keep your fuel tank full after every ride and your problem will be solved.
Old 02-09-2012, 04:54 PM
MacD's Avatar
Member #23099
SeaFoam Rules!!
Old 03-27-2012, 11:15 AM
sleded42's Avatar
Member #22855
I finally found out the issue with my atv! Appenently snow was drifting and blowing down into my air intake and when it melted it went into the air filter. when trying to start it moisture was being pulled into the carb. I rectified the problem by putting an extension on my intake so now it goes up under the tank fairing. i have over a 100 miles on since and no issues. Hopefully this issue may help others who are having a similar issue! Thanks to all who posted
2010 plaris sportsman 500 big bang no start
2010 polaris 500 wont run
2010 polaris 550 wont start backfire
2010 polaris sportsman 500 want start
2010 polaris sportsman 500 wont start
2010 polaris sportsman wont start
2010 polaris wont start
2012 polaris 500 sportsman has fuel and spark will not start
poaris 550 atv backfires and does not start
polaris 500 quad wont start has spark
polaris 500 sportsman will not start
polaris 500 wont start
polaris atv wont start
polaris sportsmen wont start
polaris want start
polaris wont start
sportsman polaris wont start
troubleshooting polaris 500 no start
why doesnt polaris 500 atv will not start?
2002 sportsman 400 wont start new stator. have spark wont fire roadjoker22 ATV Repair and Maintenance 9 01-18-2012 04:36 PM
Polaris wont start? Brian18 ATV Repair and Maintenance 3 08-18-2011 03:50 PM
2004 Polaris Sportsman 600 wont start PolarisWes ATV Repair and Maintenance 10 10-26-2010 09:32 AM
98 polaris trailblazer 250 wont start damclaughlin2000 ATV Repair and Maintenance 5 07-24-2010 02:32 PM
500 polaris wont start. need help please DJ harrison Polaris Sportsman 6 01-31-2010 07:53 PM
