01-31-2012, 12:32 PM
Member #22682
I need help with a winch purchase please. L@@K
I have a 2008 500HO EFI touring sportsman. This beast is almost 800 pounds dry. First off I need winch advise. I have searched this forum with no avail. What pound winch should I get for this big rig. I won't be mudding it or using in extreme conditions. Mostly just trail riding with my 6 year old son. I don't want to be stranded in an area that a which would have pulled us out. Second is what brand? I would like to stay around 200-300 at most with a synthetic rope as well. Lastly what GEN is my wheeler? I see gen 2 all the way to gen 6. Just a noob question.  thanks for your advise ahead of time as well. Oh, I will need a complete kit including mounting brackets as well.
Blessed regards,
Rick Feist and family
01-31-2012, 01:07 PM
Member #2669
not sure what generation sportsman you have. but i would say you need at a minimum a 2500 pound winch. i have a viper max 2500 for my 850 touring and it does fine and it won't break the bank as compared to a warn winch. that being said warn products are hard to beat. but since i've owned my winch i've used it 3 or 4 times at most. hope that helps....and get the synthetic cable, its nice to have.
Ransom Proctor
2010 Polaris Sportsman 850 Touring with EPS
2012 Polaris Ranger 800 Sunset Red LE with EPS
2007 Sportsman 450
2006 Predator 90
01-31-2012, 01:15 PM
I'll let others handle the "which winch should I get" question. I wanted to make not you do not have a generation. They stopped using the "Gen" numbers after 2004, which was Gen VI machines.
The first Rangers back in the day were called "Series" instead of model year. For some reason, Polaris way back when used "Gens" and "Series" instead of model years to designate their year.For instance, you would have a series 10 ranger, or a Gen VI sportsman, not a 2004 ranger or sportsman. Like I said, that ended around 2004.
I would got 2500# min for the winch. 3500# if you can afford it.
01-31-2012, 01:18 PM
Member #22682
Thanks for the answer on the "GEN" question. As for your viper 2500 pound winch, I see them on eBay for 129-229 depending on the poundage. Did yours come with mounting hardware and brackets for complete assembly? Do you remember what you paid for yours? Thanks in advance, Rick Feist and family
01-31-2012, 01:47 PM
Member #5212
I have the Superwinch Terra 35 on my 700. I bought the winch on Amazon with a wire cable and it had free shipping. Before installing, I replaced the cable with a synthetic rope. For some reason, it was cheaper to do it that way. I bought the mount from KFI and it's a perfect fit. I've done some heavy pulling and had the winch submersed many times with never a hiccup.
Stew
01-31-2012, 01:52 PM
Member #2669
i ordered mine from motoalliance directly. can't remember exactly what i paid for it but it came with all the mounting hardware that i needed. go to Moto Alliance and it has a lot more info. you can even see if its cheaper to buy off ebay or from them directly. good luck.
Ransom Proctor
2007 Sportsman 450
2006 Predator 90
01-31-2012, 02:00 PM
Member #14376
2,500 lb. winch should be plenty. Had one on my X2 and it was never lacking. As for brand, I prefer Warn, but the XT25 will be at the high end of your range. Around $320. The RT25 is about $50 cheaper and has the steel cable. Tough to beat the quality of a Warn, but there are many good winches out there.
Check out 4wheelonline for the best Warn prices.
01-31-2012, 02:41 PM
Member #19332
I own the Polaris 3500lb winch and also purchased the wireless remote. It may be overkill because I'm not a mud bogger either, but my theory is this; anything that will keep an 800lb ATV + a couple hundred pounds of gear + 400lb owner from hiking out of the forest after a worst case scenario is worth the money in my opinion.
Always buy the strongest you can afford. I bought my winch from the dealer because I can get it fixed there on the cheap if it fails. I am leery about brands I have never heard of. There are many good ones out there, send Thor a private message and see what he can do for you as well. He is a retailer and a very good resource for Polaris aftermarket.
But again, most people consider winches to be safety items, as do I. Don't cheap out on safety!
Peace;
Patrick
2011 Sportsman XP 850 EPS
Nicknamed "KATT" (Kickass All Terrain Toy)
Polaris Lock & Ride Front Storage Box
Polaris Lock & Ride Rear Storage Box
Polaris Deluxe Front Brush Guard
Polaris Deluxe Rear Brush Guard
Polaris Handle Bar Guards
Polaris Lock & Ride Back Rest
Polaris 3500lb Winch Kit
Polaris Winch Accessory Kit
Polaris Wireless Winch Remote
Polaris Trailerable ATV Cover
Polaris Hand Warmers
Polaris Thumb Warmer
GoPro HD Helmet Hero Camera
"I fire up the willing engine,
Responding with a roar.
Tires spitting gravel,
I commit my weekly crime..."
01-31-2012, 04:26 PM
Member #17976
Whatever you do, DO NOT buy from 4wheelonline. It will be about a month before they will let you know that you will not get a winch. I'm waiting on my refund so I can buy one from rockymountainATV for about 20.00 cheaper. If you want more info on 4wheelonline, just do a search on them for reviews and you will see.
01-31-2012, 05:13 PM
Member #21883
I just bought a viper elite 3500 from the atv super store ( www.theatvsuperstore) all and talk to thro great guy great service I order it on a Wedsneday night and had it in my hands on Friday afternoon. I cant say enough about motoallance or atvsuperstore.
2500 or 3500 lb winch for sportsman 850, is 3500 lb winch overkill for atv, polaris ranger, polaris sportsman 300 winch, polaris sportsman 850 warn winch price, want to buy a polaris touring atv, warn winch 2012 mudd feist, what gen is my 2005 polaris ho, what winch for my 2012 polaris touring, what winch should i buy for my polaris sportsman 850, will a viper max winch fit in a kfi mount, winch on 2007 sportsman 90
