02-01-2012, 04:00 AM
Member #6943
2007 sportsman 800 leaking anti freeze
Leaking anti freeze from what seems like behind water pump, I might be wrong but it seems that it is acually leaking behind where the water pump cover is. By that I mean not the water pump gasket but just past that...does this make any sense to anyone?
Gat
02-01-2012, 04:25 AM
leaking out the weep hole, mechanical seal needs replaced
02-01-2012, 04:43 AM
Member #6943
leaking anti freeze
This seal you speak of, is there just the one or inner and outer? Does the seal just pull out like a oil seal would do?
Thank you for your reply.
Gat
02-01-2012, 04:55 PM
gotta remove fly wheel, need a puller, do you have a manual? think ther is one at top of atv repair and maint page in the stickys
02-20-2012, 08:11 PM
Member #23013
replacing the seal for the waterpump is not for the faint at heart as there is alot of stuff to pull off. if you do not have the special seal installer you will damage the seal. buy the installer! it will make your life alot easier.
02-21-2012, 03:25 AM
Member #6943
I went ahead and took to my dealer. For 130.00 in labor it's a no brainer, as you stated there is is just way to much that can go wrong. Thanks everyone for replys. Got the machine back last week, rode this past saturday all is well.
Gat
02-21-2012, 03:41 AM
Member #23019
good deal, 130 isn't bad, if it was a arctic cat you'd be crying LOL
02-21-2012, 04:07 AM
Member #6943
does anyone have a service manual for 2005 sportsman 500 H.O. Buddy of mine just bought machine no manual for it.
2007 polaris 500 leaking antifreeze, 2011 polaris sportsman 800 dripping coolant, atv leaking antifreeze, polaris sportsman 800 antifreeze, polaris sportsman 800 antifreze, sportsman 800 water pump
