02-01-2012, 08:40 AM
Member #22866
Need information on changing water pump and oil seal
Not sure if there is a thread already on this or not but How hard is it to change the water pump and oil seal? I read about a special tool that is needed and only available to dealers. Is that the case or can I do it at home?
02-01-2012, 10:11 AM
Member #10305
02-01-2012, 10:31 AM
Member #22866
1999 Polaris Sportsman 500
02-01-2012, 12:07 PM
Member #10305
are u talking about the mechanical seal at the water pump, if so u don't need the special tool, it makes it a lot easier with it though
02-01-2012, 04:45 PM
Member #17976
Don't mean to rob this thread, but I have a 05 Sportsman 700 with the same problem. Are these two made the same and if not will I still need the special tool to replace the seal?
02-02-2012, 03:15 AM
Member #22866
Yes, the mechanical seal as well as the seal behind it and the oil seal. I am going to replace those three. Hopefully this will resolve the issue. I ordered them last night. Without the tool, what is the process and is that tool only available to Polaris dealers. I have a friend who is the head tech at another local powersports dealer and he has a tool I can do it with. Will his work?
1999 polaris 500 water pump schematic, 2006 polaris sportsman 500 water pump seal removal tool, change waterpump in a polaris 500, changing waterpump on 700 polaris, how much to replace polaris sportsman waterpump seal, how to change the waterpump in a sportsman polaris 500, how to remove water pump on polaris 350 sportsman, how to replace oil seal polaris 350, how to replace water pump on polaris 350l, polaris atv water pump, polaris sportsman 400 oil seal installation, polaris sportsman 400 replace oil seal, polaris sportsman 700 water pump seal, polaris sportsman water pump seal, polaris water pump seal tool, replacing polaris sportsman water pumps, sportsman 600 water pump replacement, sportsmann 500 waterpump seal removal, water pump for 2006 polaris sportsman 450, water pump location polaris 600
