Old 02-01-2012, 03:41 PM
knotready's Avatar
Member #12793
front diff
attemted service hubs completley apart cleaned torqued 145 in pounds?pulled drain plug diff nothing added oil runs out input bearing gone looks pretty simple any suprises o-ring little bushing new roller bearing seal
Old 02-01-2012, 04:49 PM
cant under stand your post, front diff seal leaking?, pinoin bearing gone where front drive line goes in?
Old 02-01-2012, 04:59 PM
knotready's Avatar
Member #12793
yes russ c 500 ho
Old 02-01-2012, 05:23 PM
knotready's Avatar
Member #12793
front diff
ok 2002 500 ho front end pinion seal and bearing need replacing i see there is a bushing or pilot bearing in the housing for the pinion / roller bearing /o-ring /seal . it looks like a roll pin on the driveshaft where the yolk slides on the pinion .will the shaft slide to the rear.or slide the diff forward or remove the whole thing ?
Old 02-02-2012, 04:23 AM
yes shaft slides back after roll pin removed then will come out right side, I would remove diff to fix it, only 4 bolts under neath and unhook wires
Old 02-02-2012, 03:00 PM
knotready's Avatar
Member #12793
front diff
thanks russ c orderd parts today nobody stocks any parts for the polaris
Old 02-03-2012, 05:46 PM
knotready's Avatar
Member #12793
front diff
pulled the front housing today. put it on the lift took about an hour. pulled it apart pinion bearing wasted full of mud. looks like the side ring bearing/bushing one side is a sealed bearing?and the other side has a brass bushing/seal anybody ever crossed seals and bearings into easy to find part numbers.
Old 02-04-2012, 04:10 AM
take old bearings to parts house, they can measure them and get the right ones
Old 02-09-2012, 02:48 PM
knotready's Avatar
Member #12793
front diff agravated 02 500 ho
did the hubs 15.00 dollar polaris demand drive oil.replaced pinion bearing ring gear bearing 15.00 polaris angle fluid . on the lift left front locks only when i supply power and ground at about 10/15 miles per hour right front nothing. ohms read the same a little high but the same speedo works i'm lost
polaris ring pinion
powered by vbulletin bearing
powered by vbulletin pinion bearing
front diff charc9 ATV New Members 1 12-27-2011 04:52 AM
Front Diff skud_rider ATV Repair and Maintenance 0 06-17-2011 05:10 AM
Why does front diff. take ATF? commosmart1 ATV Repair and Maintenance 4 04-13-2011 03:01 AM
front diff oil refg3880 ATV General Discussion 5 02-01-2011 08:23 AM
550 front diff highpie Polaris XP 9 11-27-2010 05:52 AM
