Old 02-01-2012, 04:51 PM
stang7tl's Avatar
Member #21650
backfire and broken keyway
so my 2001 500 HO backfire sometimes seem only when the float stick and I shut it of then fire it up again it has broken the keyway and help?
Old 02-02-2012, 04:25 AM
if float stuck , checj=k crancase for gas in oil
Old 02-02-2012, 08:00 AM
stang7tl's Avatar
Member #21650
this is current top dead center and where the flywheel is set and how far pass the pulse sensor the striker is
Old 02-02-2012, 08:12 AM
stang7tl's Avatar
Member #21650
so as you can tell at TDC the signal to spark has already happened. I was thinking it needed to be at TDC as the signal get sent. just ready some info online says it does need to be a bit before TDC. Please if anyone can help.
If I put a new keyway in it starts right up will idle and will rev up seemed fine. then it random broke another key so my question is can the float randomly getting stuck make it backfire? Lastly a local bike shop said the keyways are made to break if the bike backfires to prevent other damage does that sound right? I thought the Keyway I got was just junk
Old 02-02-2012, 08:22 AM
kcaves's Avatar
Member #10305
it does need to fire before TDC, and I've never heard of the keyway breaking off because of a backfire, sounds like a load of crap to me, only machine I've ever seen do that on a regular basis is the predators
Old 02-02-2012, 08:38 AM
stang7tl's Avatar
Member #21650
really would like to get this figured out the I bought the bike for myself for christmas(Thanks to a refund of a costa trip for the girl and I since she failed out of the relationship lol) I have put a lot of new parts and fun toys on it but yet to really ride it
here she is day one in the truck
all my hard work
28" mud bugs ready when I go test run it
how to find top dead center on a predator
predator 500 keyway
pulse sensor atv
tdc mark on polaris flywheel
what to do about a smashed keyway
Backfire jakes99trailboss ATV Repair and Maintenance 1 12-27-2011 05:05 AM
850 xp backfire??? pureXP Polaris XP 10 09-19-2011 06:31 AM
Backfire mikey Polaris XP 5 05-10-2011 06:29 AM
Backfire!!!!!! bb66chevelle ATV Repair and Maintenance 9 02-12-2011 10:06 AM
850 xp backfire Frank Fox Polaris XP 8 01-01-2011 02:35 PM
