02-02-2012, 10:15 AM
Member #22344
Lift and axle questions
I have a 05 sportsman 700 with a gorilla 6 inch lift and I keep breaking rear axles is there any other brands that are any good and are the axles with my lift longer than stock
02-02-2012, 11:23 AM
02-02-2012, 11:24 AM
Gorilla axles!
02-02-2012, 12:02 PM
Member #9763
First off, what axles are you running? Secondly, are you sure it is a gorilla lift? What kind of riding are you doing? Are you breaking the axles in properly? And yes, your axles for a 6" are longer than stock. Best axles on the market are Gorilla and Turner axles. Highlifter just came out with new axles but I have no idea what applications they have them for, and there is no real world reviews on them yet because they have only been out for 2 days.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
02-02-2012, 05:22 PM
Member #22344
I hAve gorilla axles all the way around I broke one so I bought a new one but my other one keeps destroying cv joints. Yes it's a gorilla lift And I ride alot of water and creeks and some mud mainly sand And never heard of breaking one in
02-03-2012, 06:20 AM
Member #9763
The break in may be part of your issue. With the angles you are running the joints heat up and get hot. To break them in properly you need to ride it untill they are warm, let them cool, and then continue this process. It states it in the instructions you get with the gorilla axles. Also with that lift you don't much want to cruise at high speeds. Maybe no more than 30mph and only for a very short period of time. This again is because the angle on the axles causes them to get hot and you will destroy your joint.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
02-05-2012, 04:57 PM
Member #22344
I will Try that onnmy next one. Another question. My bike only goes like 20mph it has low neutral and reverse no high or park The guy I bought it from said that it has gear reduction does that sound right
02-05-2012, 06:49 PM
Member #9763
It just sounds like the person you bought it from went the cheap route on putting in a gear reduction. I looked into gear reductions at one time and heard of people putting gears from a 330 magnum in their sportsman. Highlifter also sells a gear reduction kit, but both of these methods would still allow you to have your high gear and park. You would have to tear the transmission apart in order to see what he did. Or just try to get all the details from him.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
02-10-2012, 01:39 PM
Member #18757
Sounds like you bought a can of worms! Too much lift for your riding, and no idea of what parts you got. plan on lots of wrenching till you know what you have and how to use it.
CB
2007 Sportsman 800X2 two up weekend cruiser with Warn 3000# winch front and rear bumpers and backup light and 3 lamp highbeam mods, soon to have 14" wheels and 26" tires (Our trail machine)
2005 Sportsman 400 with Warn 2000# winch and EBS clutch conversion front bumper and 3 lamp high beam mod (Mamma's)
2000 Sportsman 500HO EBS with Warn 2500# winch and 3 lamp high beam mod (My wood cutting mule)
02-10-2012, 10:00 PM
Member #11816
turner and rhino choice is rhino for me though
2001 Polaris sportsman 400 4x4 olive/ sage green
2012 polaris atv axles, are gorilla axles longer for a 6inch lift, gorilla axle angle, gorilla axle break in period, how to break in gorilla axles, polaris 330 transmition gear reduction, polaris 700 sportsman turner axles, polaris magnum 330 gear reduction, polaris sportsman 500ho gear reduction from magnum, polaris sportsman 700 6 inch lift, putting 330 magnum gears into a polaris sportsman 800, sportsman 500 with gorilla lift, sportsman 800 6in lift, super atv lift with gorilla axles, triangle atv back rack price, turner gear reduction rzr price, what angle are your stock axles at with 2 inch lift from rdc, what axles do i have to have for an atv lift, whats a turner gear reduction for a polaris razor for, why does my axle on my atv keeps breaking
