Check the charge on the battery. If it's good, then it sounds like maybe you have solenoid issues. If you aren't getting a click, then try jiggling and/or cleaning the cable connections to your battery, the starter, and the solenoid on the battery and the starter side. Also check and clean the connections of the smaller wires on the solenoid. If still nothing, turn the key to the on position and try jumping the solenoid terminals with a screwdriver. If still nothing, then either the ignition switch is bad, a wire is bad from your ignition switch to the solenoid, the solenoid isn't grounded (the small brown wire. If it starts, you need to replace the solenoid. A multimeter or continuity tester will be your friend on this one.
Stew
