Water Temp Sending unit- 06 500cc
Quick Version- What should the resistance be on a cold sending unit for water temp.
The rest of the story:
I am getting the Check engine/ hot trouble code from the minute I turn the power on with a dead cold engine. It has done this before when the connector going to the water temp sending unit was not making a good connection. A mouse has chewed the wire a bit, but it is not shorting anywhere that I can see. I seperated the wires all the way to the sender to make sure I did not have a line short..
What should the resistance be on the sending unit? Can you even ohm the unit to see if it is bad?
Thanks in advance for your response.
Jay
