Old 02-02-2012, 03:09 PM
matt0304's Avatar
Member #22522
weak spark
1999 sportsman 500 weak spark has new stator cdi and ing coil dont no what else to do
Old 02-02-2012, 08:35 PM
matt0304's Avatar
Member #22522
any ideas people instead of just views
Old 02-03-2012, 05:12 AM
Kevcules's Avatar
Member #14887
If anyone had ideas , they would post them and not just view....
When you say weak spark , is it a orange colored spark or you think it's not starting because of weak spark. You have changed pretty much all the electrical components that create spark , can't see how it would still have weak spark??
Kevin
Old 02-03-2012, 07:44 AM
matt0304's Avatar
Member #22522
no its a blue spark but when i compared the spark to my big bear spark it was way smaller not as bright
Old 02-03-2012, 12:17 PM
Kevcules's Avatar
Member #14887
If the spark is blue-white , then it should be good, something else is wrong. Did you change your spark plug lately? Maybe you should try a new one. What happened to it ,for it not to run?
Make sure you're getting fuel to the carb. Try draining the float bowl with the little screw close to the bottom of the carb. If lots of fuel comes out , not a fuel issue at least to the carb. Will it try to start at all? Try putting a little fuel in where the spark plug goes. If it wants to start , then you probably have a clogged "jet" in the carb and need to take it off and clean it.
Kevin
Old 02-03-2012, 08:48 PM
matt0304's Avatar
Member #22522
yea it has a brand new plug in it n its getting fuel to the carb(just rebuilt it) but no it just turns over does not even try to start or putter but i call the people i got the stator from n they shipped me out a new today so if that dosent work imma brin it to a shop.it ran 8 months ago then sat it a shed n hasent ran since i got it n thanks for helping
Old 02-04-2012, 08:20 AM
Kevcules's Avatar
Member #14887
Good to hear the company is trying to help out with a new component, it's not the first time an electrical part is not quite right.
You say it sat for 8 months, you did get all that gas out of the system first before trying to start? Old gas can easily gum up your system and cause it not to start.
Did it run "after" the carb was rebuilt? If not, I would suspect the carb has something wrong with it still..... Does your spark plug get wet with fuel ? I'm just wondering if the fuel is making it to the piston..... Fuel may be in the carb but it has to be able to be drawn to the combustion chamber to ignite. That's why if you pour just a little bit of fuel down the hole where the plug goes , if it tries to run , then the fuel isn't getting there on it's own for some reason. (plugged jet , etc)
I'm interested to hear what fixes your issue. Normally a blue white spark has lots of capacity to ignite fuel. It may not have as much "power" if the spark is a little less than it should be , but definitely should run. When your spark is an orange color , then that's weak spark for sure and won't ignite the fuel.
I'm leaning towards a fuel issue.... Good luck.
Kevin
Old 02-13-2012, 05:49 PM
matt0304's Avatar
Member #22522
well got the new stator in and the spark is great now and it started right up for about 15 mins now wont start its driving me crazy
Old 02-13-2012, 07:32 PM
macka's Avatar
Member #23019
back to suspect fuel. I'd also suggest changing the filter when you change the fuel.
Old 02-19-2012, 12:41 PM
matt0304's Avatar
Member #22522
got it running the key on the flywheel was broke.
atv weak spark
big bear weak spark
my big bear has week spark
polaris 300 atv weak spark
polaris 500 weak spark
polaris atv has weak spark how do i fix it
polaris sportsman 90 wet spark plug
polaris sportsman weak spark
polaris weak spark won't start
sportsman 90 weak spark
weak spark polaris 90cc
weak spark polaris sportsman
weak spark matt0304 ATV General Discussion 1 02-02-2012 08:35 PM
weak spark midgey317 ATV Repair and Maintenance 4 05-22-2011 07:48 AM
weak spark? Please help! Polaris27 ATV Repair and Maintenance 4 02-07-2011 05:07 AM
Weak spark ford_boy ATV Repair and Maintenance 0 10-14-2010 02:04 PM
Sportsman 90 weak Spark prinsloos ATV New Members 3 05-24-2010 01:40 PM
