Old 02-03-2012, 07:34 AM
scat6's Avatar
Member #22929
2004 700 EFI only runs on one cylinder untill warm and ildes rough
Hi all, I'm new on here so any help would greatly appreciated!! I've got a 2004 700EFI that only fires on one cylinder when its cold out (cold being under 30 degrees or so). Once it warms up for a minute or two it fires on both and is fine all day. It also idles rough and dies at idle quite often. I've changed the plugs, put on a new T-BAP sensor, ran sea foam through it, had the CPS changed, still nothing helps. Once it's up off idle it runs great and doesnt skip a beat. Any thoughts?
Old 02-03-2012, 07:37 AM
scat6's Avatar
Member #22929
I've also tried adjusting the throttle cable and that doesnt seem to help either.
Old 02-03-2012, 07:52 AM
Old 02-05-2012, 06:15 AM
4wheelindad's Avatar
Member #22913
Checked compression?
Have you checked compression on both cylinders with the engine cold? I'm new to Polaris so maybe someone else has some better info, but if a valve is out of adjustment it might be held slightly off the seat until warm. This would show up as a low compression reading when cold. Low compression effects idle the most because at higher speeds the combustion event occurs before significant compression can leak off. Just a thought. Good luck
Old 02-05-2012, 08:54 AM
dirtdigger's Avatar
Member #20427
Coil?
Old 02-05-2012, 11:26 AM
scat6's Avatar
Member #22929
I've though about it possibly being coil or some kind of spark issue, never thought about the compression though. The thing is, and i guess I should have mentioned this before, if I crack it about 1/4 throttle while its cranking it will fire up on both cyliners every time, but still idles real rough at about 700-800 rpms and will die more often than not, but if I baby sit it and keep the r's up around 1500-1600 it's fine and runs good after it gets to temp.
2004.5 700EFI Sporty
26x10x12 Dirt Devil XT fronts
26x12x12 Dirt Devil XT rears
custom rear bumper
2500lb warn winch
K&N air filter
60" cycle country plow
Old 02-05-2012, 03:04 PM
Member #22913
Still think it could be compression
Still sounds like a compression issue. If it were a coil I don't think it would matter if you held the throttle open. Usually coils fail when they get hot. Take both plugs out and screw a compression gauge into 1 cylinder and crank engine 4 or five strokes [about 3 seconds] with the throttle held wide open. Repeat for the other cylinder. Be careful of the spark plug wires so you don't get zapped.
Old 02-05-2012, 04:21 PM
scat6's Avatar
Member #22929
4wheelindad do you know what the compression should be? Just wondering...
custom rear bumper
2500lb warn winch
K&N air filter
Old 02-06-2012, 01:19 PM
Phil030's Avatar
Member #16179
Factory specs in the manual I have say compression is 150 - 170 psi.
Leakdown service limit is %10 (which seems rather low to me, but I am new to ATVs).
Old 02-06-2012, 02:51 PM
unclekato's Avatar
Member #19204
I would also check compression. Could be a leaky head gasket.
2008 500 efi, oem front and rear bumpers rear rack 2500lb polaris winch
07 polaris sportsman 700 efi compression
700 efi 1 cylinder low speed
polaris 700 running on one cylinder
polaris sportsman 600 compression 2004
sportsman 700 dropped cylinder
Runs rough at a low RPM after warmed up Nodak ATV Repair and Maintenance 6 07-10-2011 05:22 AM
05 500 Sportsman Hard Start When Warm and Rough Idle theheisk Polaris Sportsman 4 04-05-2011 08:10 AM
800 touring runs rough jerry1230 ATV Repair and Maintenance 1 09-28-2010 05:45 AM
96 explorer 400 4wd runs rough abronfuller ATV New Members 1 10-11-2009 05:25 PM
96 explorer 400 4wd runs rough abronfuller ATV Repair and Maintenance 0 10-11-2009 04:28 PM
