If you have EBS only use a EBS belt on it. However if it's non-EBS either belt will work. The EBS belt has the grooves that matches the belt. If you put a non-EBS belt on the EBS machine it will sometimes cause it to creap in neutral and it will start to move as soon as you put it in gear. You can buy an aftermarket belt from a parts store. GATES brand makes a belt called a G-Force it looks good. Its a new product. I got one and put it on an atv it worked good. I have sold 3 or 4 at work without any problems. Where I work we warranty those belts.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again  )
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
