Old 02-03-2012, 08:27 AM
hillbillyhayes's Avatar
Member #19787
06 Sportsman 800 4x4 issues
I have a 06 sportsman 800 efi and i dont believe the 4x4 is working correctly. When I put it in to awd it works great and no problems but when i stop and put it back in 2wd as soon as the rear tires spin a little bit the frontend will lock in. If you put this into 2wd the front tires are not suppose to kick in at all has anyone had this problem or know what it could be. Thanks
Old 02-03-2012, 11:10 AM
scat6's Avatar
Member #22929
My '04.5 had the same issue untill it locked in while in 2wd and EXPLODED the front diff. I orderd the new "updated" front diff and $700 later all my troubles went away, no problems since. I'm sure theres a cheaper way to fix it though.
2004.5 700EFI Sporty
26x10x12 Dirt Devil XT fronts
26x12x12 Dirt Devil XT rears
custom rear bumper
2500lb warn winch
K&N air filter
60" cycle country plow
Old 02-05-2012, 06:57 AM
Member #19787
But you never figured out why it was doing that
Old 02-05-2012, 08:57 AM
goombadi99's Avatar
Member #2057
Ive read about the cage in the front being broken or cracked witj the same symptoms.
2011 850 xp
3000 winch
polaris hand gaurds
front lock n ride box
rear lock n ride backrest,box
Big Gun eco slip on.
27in ITP XTR Tires
Old 02-05-2012, 09:26 AM
lost cause's Avatar
Member #9763
Wrong fluid, dirty fluid, cracked/broken sprague cage, and warped armature plate are the main things that can cause this. Start with flushing the fluid a couple times with the proper polaris fluid then if that doesn't work take the diff apart and look at the cage and armature plate. If broken/warped then replace.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
04 sportsman awd armature plate.
06 sportsman 800 common problems
polaris 800 armature plate issurs
polaris 800 atv problems
polaris 800 sportsman issues
polaris 800 sportsman problems
polaris sportsman 800 4wd kicks in while in 2wd
polaris sportsman 800 4x4 problems
polaris sportsman 800 issues
sportsman 800
Sportsman 700 issues ffmike Polaris Sportsman 6 07-12-2011 04:16 PM
i need help 01 sportsman 500 awd issues....... prkchp76 Polaris Sportsman 5 01-15-2011 06:20 AM
03 Sportsman LCD issues mikeirwin88 Polaris Sportsman 7 10-23-2010 05:06 PM
98 sportsman 500 awd issues Ontario Bob ATV Repair and Maintenance 1 05-04-2010 05:13 AM
94 Sportsman 400 issues tj200 ATV Repair and Maintenance 2 06-17-2009 10:05 PM
