Hard steering 2000 sportsman. Any tips?
I have a thread in another forum but i figured i would start one here. So here it goes
2000 sportsman 500 1900 miles, just replace ball joints,tie rods,struts and greased everything in the front end and changed the hub fluid. I also spray lubed every moving part i seen that didnt have a grease fitting. I feel that the steering is still tougher than it should be. Its never been wrecked. My father has owned it since new. I put the bike on jacks to check the awd and the front hubs are not engaged. Also the alignment is good. Front tires have 8 psi in them are original and pretty worn, so im sure thats not helping me. Has anybody figured out any solution to the hard steering issue? Thanks for your help!
