Old 02-06-2012, 03:26 PM
emt39448's Avatar
Member #20870
When in AWD front diff popping some times.
I was out mudding some and got stuck. I switched over to AWD then gave it throttle. Then front diff popped a few times and I let off. I put it in reverse awd and it backed out without popping. It did it more than once. When it pops the tires dont turn. It still pulls in AWD as long as Im not on it hard.I have 27 inch outlaw's on it and also have my rear springs on stiffest setting. I also put highlifter springs on the front but no lift kit...... Think it could be too high for stock axels???? Anyone have any ideas??
Old 02-06-2012, 03:53 PM
superdad5911's Avatar
Member #21325
Could be the sprague in the diff I had to change the one out in my daughters 04 1/2 witch is the same as the 05. Super ATV has an aluminum one that will fit several models, their not that hard to change out. Or it could be the CV depends on how many miles,age etc.
03 Polaris 500 HO 2" lift
(28 Mudzillas, snorkels,
big bore kit)
04 Polaris 500 HO 2" lift
(28 Mudbugs)
07 Polaris X2 500 HO 2" lift
(Winch to pull the others out)
Ride with NDC Trailriders
Old 02-06-2012, 04:47 PM
Kandgo's Avatar
Member #20531
It is your front sprague. Your big tires are causing it to skip when in a real bind. You can change it out, but the Aluminum one will do it also if your tires are to big and in a real bind.
Old 02-06-2012, 05:58 PM
lost cause's Avatar
Member #9763
Agreed here with it being the plastic sprague cage in the front diff. It is probably cracked/broken. Since you run outlaws I recommend the aluminum one from superatv. Go ahead and get their armature plate as well. I run 29.5 laws with no issues since installing the aluminum cage.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 02-06-2012, 06:31 PM
emt39448's Avatar
Member #20870
Thanks so much guys! I had no idea about this thing. I was thinking I was in for some big money repairs. Looked the parts up and they are cheaper than I thought. 170 bucks isnt bad at all! any other issues you guys can think of going with these outlaws. Im looking at bigger tie rods and spare ends as well.
Old 02-07-2012, 04:26 AM
Member #21325
Be easy on the gas when in any mud with roots but that goes for any tire, sometimes it better to ease through than gasing on it.
big bore kit)
(28 Mudbugs)
Old 02-07-2012, 01:33 PM
lost cause's Avatar
Member #9763
With outlaws you will eventually need better axles like gorilla or turner. Also a gorilla rear prop shaft as the U-joint will eventually go bad. Custom clutch kit is also nice to have to help get you through the thick stuff. As far as your tie rods go, I just keep a spare. I run 29.5 outlaws and have only bent 2 tie rods.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
04 polaris front lift kit
front popping polaris
lift kit polaris sportsmen front end popping
polaris 400 sportsman front end popping
polaris 500 front end pop
polaris 500 popping in front end
polaris awd poping
polaris front end popping
polaris popping front end
polaris sportsman popping
sportsman 400 ho front end popping and pulling right
front diff charc9 ATV New Members 1 12-27-2011 04:52 AM
Popping noise in lft front hub??HELP gobucks85 ATV General Discussion 2 11-10-2011 07:07 AM
Front Diff skud_rider ATV Repair and Maintenance 0 06-17-2011 05:10 AM
Why does front diff. take ATF? commosmart1 ATV Repair and Maintenance 4 04-13-2011 03:01 AM
Front differential popping and clicking Hemi26 ATV Repair and Maintenance 8 04-03-2011 08:03 AM
