Old 02-06-2012, 06:45 PM
jonslink's Avatar
Member #3179
Removing rear axle
Hey, I'm sure this has come up several times. I was trying to take out my rear axle and it disconnected right at the rear differtial, it's where the small shaft goes into the big cylinder..(sorry not a mechanic) anyways now I'm stuck with getting the short fat cylinder out.... Any help would be great....also how hard is it to replace the seals where these axles go into the rear differtial? Thanks
This is 2002 sportsman 700 twin. Manufactured 03/02
2002 sportsman 700
26" mud zillas
Old 02-06-2012, 08:45 PM
focushunter's Avatar
Member #9482
Should be able to pop it rigjt out. Stick a pry bar in it just make ur not to use your diff to pry on.
Old 02-07-2012, 07:14 AM
jonslink's Avatar
Member #3179
Ok thanks I soaked it in PB blaster last night, I'm gonna try taking a pry bar to it this evening.
2002 sportsman 700
26" mud zillas
Old 02-07-2012, 07:48 AM
POLARIS13's Avatar
Member #20347
i had to change the seals in my 09 800 EFI and you have to take both axles out, and disconnect the rear diff....there are alot of bolts, so remember where you got them out of, because some bolts go all the way through and some just screw in the diff to hold it there. but thats just for mine, not sure on yours. and as the axles go, just stick a bar in between like FOCUSHUNTER said...but its alright if you pry on the case...wont hurt it at all....it is aluminum so it will scratch with your bar, but nothing to worry about.
Once you get everything off, the case can be taken out. Remember to disconnect the vent tube. after that, take off the 8 or so bolts holding it together. get it open and the big disc gear will come out. Take a socket or section of tube that is the right size and pound out the old seals....putting the new ones in is a little tricky! After you have it all done, i would suggest putting a silicon gasket maker in the place where the two halfs come together. Any questions, just ask. I have had my rear diff out 3 times to figure out what a noise was, and once to change the seals!
Old 02-07-2012, 04:35 PM
jonslink's Avatar
Member #3179
Ok thanks, I'm still having a hell of a time getting the rear axle out.i ordered a cv puller that should be here in a day or 2( got speedy shipping I'm so frusturated with it) I know the axles haven't been pulled since they were put in so I imagine there rusted pretty good. I'll keep you posted how it goes when the puller gets in.
2002 sportsman 700
26" mud zillas
Old 02-07-2012, 09:05 PM
POLARIS13's Avatar
Member #20347
I personally think they are a waste of my money....just cause there is always something in the shop that can be fabbed up to make things work. but keep pounding on the shaft....it will break freee...if you have a buddy or somebody else that could do it from equal sides, that helps tremendously! otherwise, keep me informed on how the puller works..i might get an idea from it! haha
Old 02-07-2012, 09:12 PM
Member #9482
Get someone to jerk on it while you pull. And make sure when putting the new one in put a little grease on it.
Old 02-09-2012, 08:48 AM
jonslink's Avatar
Member #3179
Well the cv puller is worth the money! 3 pulls and it was out..now onto the seals my parts guy said these were serviceable from the outside of the diff, once I got the old one out I saw a set of bearings...did I screw up or is this normal?
2002 sportsman 700
26" mud zillas
Old 02-09-2012, 09:13 AM
POLARIS13's Avatar
Member #20347
Okay...but no, that is normal....inside the rear diff is a gear on the shaft where the rear axle goes into. there is a bearing on each side of that gear. You are fine! is the diff still in the wheeler!? or did you take it out!?
Old 02-09-2012, 09:45 AM
jonslink's Avatar
Member #3179
I kept the diff in the four wheeler..the parts man said i should be able to find a seal at local car parts place..do I just pop the new seal in and good to go??
2002 sportsman 700
26" mud zillas
97 polaris sportsman 500 rear axle removal
how do i replace my polaris 700 sportsman rear axel bearing
how to get rear axles out of polaris sportsman 400
how to install rear axle 500 sportsman
how to remove polaris rear axle
how to remove rear axle from sportsman 700
how to remove rear axle on polaris sportsman
how to remove the rear axle on polarid 700 sportsman
polaris 700 sportsman pry rear axle out
polaris pred 90 removing rear bearings
polaris predator axle removal
polaris rear axle removal
polaris sportsman 700 rear axle removal
pullin a rear axle 06 sportsman
rear axel removal on polaris magnum
rear axle removal from a polaris sportsman
remove rear axle for polaris sport
removing polaris rear axle
replacing rear axle polaris atv
Removing rear axle Kiwikiwi Polaris Magnum 9 01-12-2012 04:27 PM
rear axle help!!! Sweenman 88 Polaris Predator 11 12-23-2011 04:39 AM
How to Remove Rear Axle b_horner79 Polaris Sportsman 6 07-25-2011 09:26 AM
Rear Axle for 97 500 4x4 Rooster0310 Polaris Scrambler 2 07-04-2011 06:44 AM
Removing Rear Wheel Hub on a Hawkeye 300 Waymon3X6 ATV Repair and Maintenance 1 02-26-2010 01:44 PM
