Old 02-08-2012, 08:33 AM
StevenWithaV's Avatar
Member #22027
500 H.O. Starter Replacement
Took my 2002 500 H.O. to my local Polaris dealer because starter wasn't working. Ends up they say it needs a new starter drive ($109.95), bendix ($196.30), and labor of $212.50!!!
I know have seen people speak of the eBay seller "dbelectrical" out of Tennessee. He has the pair on eBay for $74.00:
NEW Starter Drive COMBO POLARIS ATV Sportsman 400 500 | eBay
Anyone had any problems out of these? Success stories? For the money, I think I'm going to have to go with this option.
I got another guy in town who will do the labor for cheaper. Thanks for the replies!
Old 02-08-2012, 09:14 AM
1of7627's Avatar
Member #4155
I bought those same parts for one of my machines and haven't had any problem.
The bendix and starter don't usually fail simultaneously. Starters wear out. Bendix's get ruined from water that gets into the recoil starter housings, causing them to rust. I've learned to keep tabs on them. If the recoil housing is ever off for any reason, it's easy to remove the bendix, clean and oil it (and put a dab of grease on the bronze bushing for the starter shaft). - MarkC
MarkC - Spokane, WA USA
Old 02-08-2012, 03:19 PM
Kevcules's Avatar
Member #14887
I've heard on here of guys getting that brand starter and it works great.
First thing I would do is remove the starter and open it up. Maybe you can just get a rebuild kit for a lot less money.
Kevin
Old 02-08-2012, 04:38 PM
db electric is the way to go, have used them several times over the years
Old 02-08-2012, 04:41 PM
Member #22027
Thanks for the reviews! I have ordered mine today, feel good about it. Will post when its installed!
Old 02-09-2012, 01:01 AM
gtxgohan's Avatar
Member #11816
im using it right now on mine and it works fine only thing im going to say is id had to replace mine housing was shit and about to break but if your housing is good get a rebuild kit its cheaper and u can go wrong for paying under 100 bucks
they wanted more than 300 to do the starter for my quad i flipped the hell out in my mind
and the 300 was minimum
2001 Polaris sportsman 400 4x4 olive/ sage green
Old 02-09-2012, 05:17 AM
Dougie's Avatar
Member #22617
I've read alot about db and people say they are good. starter was acting up for some time and finally gave out couple weeks back. since then i've been using pull start until last night when the cord broke lol so ill be ordering my starter bendix combo today from db. They are easy to change so taking it to dealer is a waste of time and money i would google around and do it yourself.
2004 sportsman 500 H.O
Old 03-17-2012, 12:10 PM
fishercat's Avatar
Member #23930
Just installed one from DB electric, works great. Fourty three dollars delivered to my house.
Old 03-17-2012, 12:35 PM
dog812's Avatar
Member #19217
I am also using the db starter.. I did a quick how to remove the old one on a 500 H.O as well..
http://www.polarisatvforums.com/foru...rter-pics.html
ran great for me so far.
For $43 how can you go wrong.. it could fail 3 times before you pay for the OEM one.
I also agree.. they most likely wont fail at the same time. If its not trying to start , its your starter. If the starter is just spinning, the bendix is not engaging.
01 polaris 500 starter
2002 polaris sportsman 500 h0 starter replacing
2002 polaris sportsman 500 ho starter
2002 sportsman 500 ho starter
500 sportsman ho starter removal
best starter for polaris sportsman
how do you change bendix on polaris 500 2002
how to get a polaris 500 ho starter off
how to grees starter in polaris 500 sp-ortsman?
how to remove a starter on 500 polaris sportsman
polaris 500 ho starter diagram
polaris atv starter drive bendix
polaris spoetsman 500 ho starter
polaris sportsman 500 ho starter oil
polaris sportsman 500 starter removal
polaris starter rusted
replace started polaris 500 ho
replacing starter on 2002 polaris 500 ho
starter bendix sportsman 500
Starter Replacement Help Hunter11 ATV Repair and Maintenance 0 02-07-2011 03:19 PM
2008 Starter Replacement p_wolf1 ATV Repair and Maintenance 4 11-27-2010 12:16 PM
starter replacement / clutch bomberboat ATV Repair and Maintenance 12 03-07-2010 07:30 AM
Starter Replacement lionsfn ATV Repair and Maintenance 2 01-16-2010 11:52 AM
250 trailblazer starter replacement? y2kshee Polaris Trail Blazer 4 11-09-2009 11:10 PM
