Old 02-09-2012, 03:53 PM
the_xukushuner's Avatar
Member #21969
04 awd NOT working, speedo does!!!
just picked up an 04 (carb) sportsman 700. awd does not work. speedo does, big handle bar guage lights up and showshours/miles/rmp. is there an awd light that is soposed to light up when locked in? also tryed in reverse/hi/low, and with override button in. never works. is there a fuse or sensor? help me guys, and thanks in advance!!!
Old 02-09-2012, 04:43 PM
MacD's Avatar
Member #23099
On my 2010 there is a little light on the cluster, not sure of your year. It is an electroniclly controled magnet the engages the awd, if its the same i would check the wire for cracks or the plug. On mine the speedo has nothing to do with the awd, it is attached to the brake on the right caliper. For your sake I hope its electrical, if not my next guess would be the roller cage inside the diff. Again not sure of your year but i know polaris used alot of plastic cages, they are pretty much junk. But in about two hours and four hundred dollars you can pull your diff out and rebuild it with a billet aluminum roller cage and new seals. Good luck in finding your prob.
Old 02-10-2012, 06:16 AM
fmartin_gila's Avatar
Member #22643
My 2004 Sportsman 500HO has an indicator in the gauge pod that shows when AWD in "on". Left edge about half way up.
Fred
Old 02-10-2012, 11:28 AM
Member #21969
thanks guys, finally i see the indicator light. turns out the awd switch on the handle bars doesnt work if you push it the whole way to the left (awd). if you bring it back a little it works great, before i take that apart, is there a way of cleaning any connecting inside of it?
Old 02-10-2012, 11:33 AM
macka's Avatar
Member #23019
electrical contact cleaner and lube. Napa carries it in the automotive section
04 sportsman spadometer problems
05 sportsman 700 speedometer not working
06 sportsman 700 awd not working but lights on
atv 4wd lights up but doesnt work
awd and spedometer stopped working polaris
awd not working
awd speedo not working 700 sportsman
how does a spedo work on atv
polaris awd not working
polaris sportsman awd not working
polaris sportsman speedometer not working
polaris sportsman speedometer not working 700
polaris sportsman, speedometer not working
polris spotsmn 700 awd light not on
speedo not working rstevens Polaris Sportsman 10 08-14-2011 10:46 AM
04 400 sportsman speedo no working wildmale28 Polaris Sportsman 6 06-12-2011 03:17 PM
Help, speedo not working. DrnknCamel ATV Repair and Maintenance 2 05-12-2011 04:14 PM
Speedo and odometer not working Polarisguy57 ATV New Members 2 04-21-2011 10:41 AM
Speedo not working on 02 Magnum 500 Mighty Mouse ATV New Members 0 08-31-2010 10:46 AM
