Wrench light on start up - Polaris ATV Forum
Old 02-15-2012, 08:41 PM
Scrambler2Sportsman's Avatar
Member #18575
My polaris service interval diagnostic mode indicator light comes on at start up. Then flashes a couple times then goes off. Is this normal?
2005 800 efi
His ~ 2013-Scrambler XP - Painted Polaris Grille Guard ~ Polaris Lock and Ride Box ~ ODI Rouge Grips ~ MSA M12 Diesel Gloss Black Wheels ~ 28x9x14 Swamplites(Front) ~ 28x11x14 Swamplites(Rear)
Hers ~ 2005 sportsman 800 EFI - Polaris Winch - 27" Outlaw MST's ~ Raceline Monster Wheels ~ FOR SALE
Old 02-15-2012, 09:07 PM
Reverse countdown hour meter. It does this when that Meyer counts down to zero to remind you it's time to service.
You can reset it in one hour increments from 1-99 or turn the feature off by going into the diagnostic mode.
Key off
In neutral
Parking break set
Wait 10 secs
Press and hold yellow override button
Turn key to on (engine off)
Should load diagnostic mode. Scroll thru using yellow override button, press and hold when at hour meter screen to reset or turn off.
Getting into diagnostic mode is from memory. Apologies if I screwed it up.
Old 02-15-2012, 09:08 PM
Member #18575
So is that telling me I need to service my rig?
Old 02-16-2012, 12:19 PM
bobx2's Avatar
Premium Member Premium Member
Member #14376
It is telling you that the hour count down meter has reached zero. I believe the factory setting when new is for 50 hours. That is what I re-set mine to after each service so I stay on my service schedule. I would guess you need to service your machine and then re-set the meter to your desired service interval. An hour service schedule is better than a milage schedule IMO.
Old 02-16-2012, 12:39 PM
Depends if whoever serviced it last didn't reset the meter. If this machine is fairly new to you, it may be best to do its service now, and than reset the meter to 50 hours so you know its good to go.
Old 02-16-2012, 12:41 PM
Diesel man 03's Avatar
Member #7294
It means that the last person that changed the oil did not reset it, or maybe it was not changed at all.
Old 02-16-2012, 05:20 PM
KICKER431's Avatar
Member #18006
Here is a link to another thread where Blueline told us exactly how to get into dignostic mode and reset the meter.
Wrench flashing on dash
hope that helps
Oops, I didn't read Blueline's comment above before posting this. I will leave it here anyway incase he did mess it up earlier but it does look right. The link is slightly more detailed.
completely stock FOR NOW
26" Maxxis Bighorn 2.0
2012 polaris ranger 500 maintenance light reset
how do i reset the wrench light on my 2012 sportsman 500
polaris ranger service light reset
polaris ranger wrench light
polaris ranger wrench light on wont throttle up
polaris sportsman 400 wrench light
polaris sportsman 500 wrench light flashing
polaris sportsman service light reset
polaris wrench indicator
service light on sportsman 110
what is the wrench when i turn on rzr
wrench flashing 2013 polaris
Wrench light on after 2 hrs?? CNEDEER ATV Repair and Maintenance 3 02-15-2011 04:04 PM
Nuetral "Green" Light ~ To Start!!! kjpacer ATV Repair and Maintenance 4 01-12-2011 06:18 PM
Maint Wrench light no showing... jshields ATV Repair and Maintenance 7 09-23-2010 12:38 PM
Sportsman 500 temp light comes on/fan won't auto start? Michigan Sportsman 500 Polaris Sportsman 3 03-16-2010 09:19 AM
battery light and wrench flashing rrrssm ATV Repair and Maintenance 3 08-23-2009 01:06 AM
