01-23-2010, 05:14 AM
Member #2531
700-800 upgrade?
I bought a 2002 damaged 700 sportsman with a hydro-locked motor. I tore down engine and the crankshaft is shot, as are the pistons(the rest is good). Does anyone know if the 800 crankshaft will fit in the 700 crankcase? If so I can get an 800 crankshaft $200 cheaper! My research shows the cylinder jug is the same. I will go for the wiseco 12:1 pistons as well, does anyone have a suggestion for a carb upgrade? Should I change the camshaft and exhaust?
P.S.
I did a little extra research and the 700-800 crankcases are one and the same(according to 2005 polaris microfiche). Still need carb advise.
Regards
James
Reason: new info
01-23-2010, 12:54 PM
are you thinking you might want to go with a bigger carb, aftermarket camshaft and exhaust for performance gains? or you just trying to stay around stock?
01-23-2010, 02:01 PM
Member #2531
I don't want the quad to be any louder, so maybe skip the exhaust. I do want to make sure I don't lean out the mixture with too small a carb, so maybe 2 jet sizes bigger might be enough to run the factory carb, the increase in compression to 12:1 might necessitate a change of carb though. I am not looking for a race motor, I would like some extra power if I and when I want it. I have a factory take-off exhaust for an 08 800 sportsman that I will probably useon this unit.
Regards
James
03 700 sportsman 800 crank, 03 sportsman 700 with 800 crankshaft, 2005 polaris 700 liberty, 700 polaris sportsman with 800 crank, 800 exhaust on 700, can i make a 700 polaris into a 800, can i make a 700 polaris sportsman into a 800, polaris 700 exhaust upgrade, polaris 700 to 800 crankcase, polaris 800 crankshaft in a 700, polaris 800 sportsman crank shaft, polaris 800 sportsman crankshaft in a 700 sportsman, polaris liberty 700/800 crankcase, polaris liberty 800 crankcase, polaris sportsman 700 exhaust upgrade, polaris sportsman 800 upgrades, upgrade polaris 700, using a 800 polaris crankshaft in a 700 polaris sportsman, will an 800 polaris engine fit into a 700, would polaris 800 upgrade kit fit 700
