Old 01-23-2010, 07:15 PM
Farmer Green's Avatar
Member #2819
Fuel Tank Foam Seal ????
Hi all!
After pulling the fuel tank from my 2003 Sportsman 700, I examined the Parts Manual and notice that I was missing the foam seal (PN 5812265). I picked one up and now I can't figure out where it goes! Anyone know where it is placed on the tank or what the purpose might be?
Thanks!
Old 01-24-2010, 05:40 AM
ill get back to you this afternoon after i get off work
Old 01-25-2010, 05:16 PM
Member #2819
Working on Sunday. No rest for the weary! Did you have a chance to think about it?
Old 01-25-2010, 05:29 PM
ahh sorry. yeah, i am a college student so i have school like 9-4 mon-friday and then i work 9-4 on sat. and sun. i consider sleeping in to be 8am, and i do that 7 days a week. haha, gotta love being broke.
okay, so here is your OEM microfiche. #3 is the foam seal you mentioned. it appears it fits like it is show on the back of the fuel tank. i dont have a mental picture exactly of your set-up though. does it look like it would fit there correctly?
if i remember right, your breather for your air box should be close by, and my assumption is that this foam seal is there to help keep the airbox form sucking in dirt and dust, and also to reduce rattle from the body plastics.
let me know if this helps you at all, and if not ill try to do some more research.
1 5433687 Cap, Gas Tank [Incl. 19] 1 Usage
2 8360009-600 Line, Fuel AR Usage
3 5812265 Seal, Foam 1 Usage
4 2520203 Asm., Fuel Tank [Incl. 13,14,18] 1 Usage
5 5182004 Foil, Fuel Tank 1 Usage
6 7052161 Valve, 3-Way 1 Usage
7 7080003 Clamp, Hose, Red 4 Usage
8 8450040-600 Line, Fuel AR Usage
9 5432733 Nut, Fuel Valve 1 Usage
10 5432559 Knob, Fuel Valve 1 Usage
11 7517505 Screw 1 Usage
12 8450080-65 Sheath, Foil 2 Usage
13 7052150 Fitting, Fuel Outlet, Main 1 Usage
14 7052149 Fitting, Fuel Outlet, Reserve 1 Usage
15 5812005 Foil, Fuel Tank 1 Usage
16 5246069-067 Bracket, Mounting, Rear, LH 1 Usage
16 5246070-067 Bracket, Mounting, Rear, RH 1 Usage
17 7517685 Bolt 2 Usage
18 5431053 Vent, Tank 1 Usage
19 5812123 Gasket
Old 01-25-2010, 05:58 PM
Member #2819
Broke student, huh? I remember those days. I worked at a Massey Ferguson dealer and always smelled like diesel when on a date. Good luck! The thing is that the piece doesn't really look like the one in the fiche! It is rectangular, about 10" by 2" with a "v" notch in the middle. I am thinking that it might go across the top of the tank toward the front with the notch at the steering post. this might prevent wear and rattles between the tank and front cab. Bit of mystery to me.
Old 01-25-2010, 06:11 PM
yeah, im broke but i work hard and get by. when i work at the shop during the summer i smell like gas and tires 24/7. doesnt bother me though
take a look at this PDF file, im getting a different picture now... it is A12 on the manual page or page 13/60 on the PDF file. does this help
http://www.worldofpowersports.com/oe...%209918743.pdf
Old 01-25-2010, 06:24 PM
Member #2819
The link points to a 2004 model and the tank is quite a bit different. Mine looks like the one in the fiche above. But, maybe there's a clue in here...I'll have to put mu thinking cap back on.
Old 01-25-2010, 06:27 PM
yeah, i wasnt sure if the 2003 and 2004 tanks were the same. i wish the fiches were a little more accurate. ill a keep digging
2003 polaris sportsman gas tank
2003 sportsman 700 fuel tank vent location
700 polaris fuel tank
7052161 polaris
air box seal
atc fuel tank gasket
atv seal-foam
gas tanks fit 2003 sportsman
how can i seal a plastic fuel tank on a atv
how do the fuel lines go on a valve,3-way 7052161
polaris 5431053
polaris 7052161
polaris atv 700 sportsman fuel tank
polaris gas tank gasket
polaris seal foam
polaris sportsman 7052161
polaris sportsman air box seal
sealing around air box fuel tank
tank fitting on polaris atv
tank foam seal
