01-25-2010, 03:37 PM
Member #2842
2004 Sportsman 500ho front axle
Newbie here. Recently installed 1.5" front lift, now axle is popping out of diff. Already replaced circlip and cleaned hub out, do I need longer axles.Currently have stock with outer cv and inner ujoints.
01-25-2010, 05:19 PM
01-26-2010, 06:35 AM
Member #618
No you should not need longer axles with a 1.5" lift.If the axle is coming out then you might want to check that clip and make sure you get the axle all the way in the diff.
06 Predator 500 TLD
07 Sportsman 500 EFI
09 Sportsman 550 XP
01-26-2010, 03:08 PM
Member #2842
Thanks for the reply SLIDER, I've already tried 3 new clips. Axle locks in hub just fine but then when I'm tightning lug axle actually pops out of diff.Quad is on lift so I realize extra stress is on axles. Once lowered axle pushes in but I can pull it out of groove for clip. Maybe axles with inner cv's will help, or maybe diff hub is wore out? Stock springs,RubberDown lift.
04 polaris sportsman 500 front axel, 04polaris sportsman 400 front diff diagram, 2000 polaris sportsman 500 front hub parts diagram, 2000 sportsman 500 front boot, 2004 polaris sportsman 500 front hub, 2004 polaris sportsman 500 ho axles, 2004 polaris sportsman rear axle circlip, 2004 polaris sportsman rear cv breakdown photo, 2004 sportsman front axel, axle problems installing a lift on sportsman 500, axle removal 600 sportsman, diagram of 2004 sportsman polaris front hub, diagram parts 2004 500 sportsman polaris, front axle replacement on polaris sportsman, polaris 500 ho front axle removal, polaris 500 sportsman parts diagram, polaris sportsman 600 front axle, polaris sportsman front axle diagram, rear axle installation schematic for 2004 polris sportsman 500, sportsman 500 2004 front differential
