EPI PATV1 Spring on Sportsman 500. Here is a pic - Page 2 - Polaris ATV Forum
  #11 (permalink)
Old 03-26-2012, 02:42 PM
Rooskey's Avatar
Member #22134
It does great. My 2011 400HO really liked it. And like you said for twenty-five dollars you cant beat it..
  #12 (permalink)
Old 03-26-2012, 02:54 PM
factionfx's Avatar
Member #20681
Originally Posted by Z-Rider View Post
What years will this work on?
As far as I know it will work on just about all 325cc-500cc 4-stroke polaris.
I only say this because I had emailed the guy at EPI back and ask him what he recommended for my 2000 Trail boss 325 and he said the same spring.
Good luck!
2012 Sportsman 500, Red.
  #13 (permalink)
Old 03-26-2012, 04:10 PM
antoniodef's Avatar
Member #11247
Just ordered one off Amazon from Powersport Superstore. $23.31
Anyone running the spring with just stock tires? Any benefit?
I plan on going to 26" BH2 sometime soon, which they run a size larger than listed. Wanted to pick up this spring and some spacers before I get the tires.
2015 Sportsman 570 Touring EPS - 26" Big Horn 2s, ITP Delta rims, Polaris 3500lb winch.
Sold - 11 TB 330, 11 SP 500, 13 SP 500
  #14 (permalink)
Old 03-26-2012, 10:28 PM
Rooskey's Avatar
Member #22134
It has nothing to do with the size of tire. It has everything to do with the weight of the tire. Most people dont consider this. Take a closer look at how much extra rotating weight you will be hauling. I bet that you will be surprised...
  #15 (permalink)
Old 03-27-2012, 08:12 AM
antoniodef's Avatar
Member #11247
I have, the Big Horns are pushing almost 2x as heavy as stockers.
  #16 (permalink)
Old 03-27-2012, 01:00 PM
Fastlane01's Avatar
Member #23455
Think I'll try this since I'm running 27x11x14's on all four corners. I did notice a very small difference but it still slings mud like crazy. Just stopped popping up on take off
I am here: http://tapatalk.com/map.php?wwnkin
  #17 (permalink)
Old 04-02-2012, 04:34 PM
antoniodef's Avatar
Member #11247
Received the spring today. Probably won't install it until I get new tires. Waiting for RDC to get spacers in stock before I order tires.
Sent from my SCH-I510 using Tapatalk
  #18 (permalink)
Old 04-02-2012, 09:37 PM
gtsum2's Avatar
Member #23200
do you need a clutch compression tool to replace the spring?
  #19 (permalink)
Old 04-02-2012, 09:51 PM
dbmachine's Avatar
Member #23588
No compression tool needed for replacing this spring..if you change the secondary then you need the compression tool..
  #20 (permalink)
Old 04-02-2012, 11:23 PM
Corbett1973's Avatar
Member #19435
I'm curious, would this be a good idea for my machine? I might order one.
07 500 EFI HO X2 Deluxe
25" Original Bighorns
Polaris HD Front springs front & rear bumpers
money is the root of all evil & man needs roots:
2000 sportsman 500 clutch modification
500 magnum primary clutch spring
change primary clutch spring sportsman
clutch
epi patv1 spring
modding sportsman 500 clutch
patv1 spring scrambler
polaris sportsman 500 primary balanced
polaris sportsman 570 clutch toque specs
sportsman 500 green spring
sportsman 500 primary spring
sportsman lower engagement spring
05 sportsman 400 clutch spring question... justin.boyea Polaris Sportsman 6 04-11-2012 11:04 PM
Sportsman 400 clutch spring? trailboss4x4 ATV Performance Modifications 1 08-11-2011 07:49 PM
05 sportsman 800 Rear spring ???? bmac6494 ATV Brakes & Suspension 2 01-27-2011 06:49 AM
help! broke spring oil pump spring! 96xpress400 ATV Repair and Maintenance 3 11-30-2010 08:35 AM
Polaris sportsman atv strut and spring Super ATV ATV Parts for Sale 0 11-29-2010 07:56 AM
