01-31-2010, 07:19 PM
Member #2862
I've got a champion winch from costco... and since I don't use it that much it does just fine for me.... Have a big champion winch on my truck too (9500) and its been doing fine and it sees a fair bit of use. Kind of slow and loud.... but it gets the job done
02-01-2010, 06:34 PM
Member #2707
I also got one from Costco $39 It's been on there for 5 years and I can tell ya it's got a lot more power than a $350 warn! And the parts are cheap; When it stops working you just throw it out and buy another one!!
02-02-2010, 08:57 PM
Member #2883
Thanks guys for all the opinions, I ordered the Warn xt25 from gander mt. $252 and change shipped to my house. Thanks "mnfatboy" for the discount code. It saved me $42. I owe you one! I also ordered a KFI Mount. Hopefully install will be as easy as I have heard it is! I'll keep you posted.
02-03-2010, 06:54 AM
Member #2824
buster, glad you were able to get the discount at gander. I just received my KFI mount for my 2009 Sportsman 500 EFI, looks like a quality piece. I hope to get the winch from Gander by the weekend to install.
02-03-2010, 12:39 PM
Member #2883
Mnfatboy, It sounds like we are in the same boat, I have the same machine. Let me know if you run into any problems with install, I will do the same.
02-03-2010, 05:08 PM
Member #1414
smart move going with the warn and KFI.
2010 550XP EPS, 26" GBC SPARTACUS
09 850XP EPS
RT30 WARN WITH KFI MOUNT
02-08-2010, 01:19 PM
Member #762
Gander Mountain just went back up to $479.00 on the XT30 and the XT25 is now $399.00.
02-10-2010, 08:52 AM
Member #2824
I finally got the winch yesterday. It took me about 2.5 hrs to install. The directions weren't very clear. It mentioned to remove the bottom tie bolt before use. I remove a long screw type items that looked pretty thin to be anything important. Any one know what this is for?
02-13-2010, 07:17 AM
Member #2883
mnfatboy, I started to install mine this week, got it all installed went to make the connections to the contactor and over-tightened one of them. It popped the threaded post off the contactor. I called Warn, and they are sending me a new contactor no questions asked. I haven't got it yet, but was pretty impressed with the customer service. It sounds like you took out the right bolt. It says it is just needed for servicing? Are you putting a plow on?
 2009 Sportsman 500 EFI (Red)
02-13-2010, 07:56 PM
Member #2824
I email warn on the bolt just to be sure and they were quick to respond. I just cut out the bumper today; looks great with the cover. The goal is to put a plow on eventually but I haven't found the right deal on one yet.
anybody used runva 2500, best winch for polaris 500 sportman, can i use a warn winch xt30 on my polaris sportsman 500, difference between warn mt and xt, diffrence between warn rt and xt winch, kfi products coupon code, kfi products promo codes, kfi products promotional code, kfi products promotional codes, polaris selling older model rt 3.0 winches, runva vs warn, runva winch vs warn, warn 3000mt vs warn xt30, warn bottom tie bolt, warn mt vs rt, warn mt vs xt, warn xt vs rt, warn xt vs warn mt, what is the difference between warn xt and rt, winch ideas
