Old 01-31-2010, 08:21 AM
mutt3497's Avatar
Member #2915
2007 Polaris sportsman 500 dead!
I have a 07 sportsman 500 efi...It started fine yesterday now nothing...when i turn the key the instruments or lights wonts even come on...brand new battery put on today...will not pull start either...every once in awhile u can hear the clicking and the instruments will flash on for a second then off again. Any suggestions?
Old 01-31-2010, 10:36 AM
HappyCamper's Avatar
Member #2191
Send a message via AIM to HappyCamper
Welcome to the forum.
Two things I can think of. Lose wire connections going maybe to the starter solenoid switch or your kill switch is malfunctioning.. Plus check both ends of your ground wire coming off the battery.
2008 Polaris Sportsman 700x2
2008 Polaris Sportsman 90
2005 Bombardier Outlander 400XP
Old 01-31-2010, 11:28 AM
pondfishr's Avatar
Member #762
This sounds stupid but have you checked the toggle switch to make sure it is in the on position on the handlebar?
Old 01-31-2010, 11:36 AM
Member #2191
It isn't stupid. My first thought was the kill switch too but he says sometimes it "clicks and the lights flash". The clicking is probably the fuel pump and I don't think it comes on when the kill switch is on. Bad ground or loose positive wire is still my guess.
Old 01-31-2010, 12:05 PM
mutt3497's Avatar
Member #2915
I checked both ends of ground on battery and hot wire also.still nothing
Old 01-31-2010, 12:11 PM
mutt3497's Avatar
Member #2915
could it be a fuse? does the 07 sportsman have a fuse box? if it does i can't find it i have looked everywhere?
Old 01-31-2010, 12:24 PM
Member #2191
The guys who know what they are talking about should be getting out of Church soon or maybe when the game is over they will answer you :-)
I have a X2 and my fuses are in the front box. Not sure where yours are but if you are getting occasional lights and clicking I wouldn't suspect a fuse. Check to see if the wires coming off the ignition switch are corroded or loose. You will see it a lot on this forum where batteries are not charged enough or a new battery is bad. Do you still get the same thing when your charger is attached?
Old 01-31-2010, 01:44 PM
mutt3497's Avatar
Member #2915
yes just put a new battery today and a maintainer...i think it might be the solenoid i can beat on it and pull on the wires around it and it clicks more...yes the toggle switch is on run
Old 01-31-2010, 01:54 PM
if you think it is the solenoid...the best way to check is to turn your key to the on position, and they put another piece of metal between the two terminals on the solenoid, like another key. if the solenoid is bad, it should start cranking as soon as you jump the terminals.
Old 01-31-2010, 02:26 PM
mutt3497's Avatar
Member #2915
i did that and it starting to try to crank...how much is a solenoid?
07 polaris sportsman 500 fuse location
2005 polaris 500 fused link
2005 polaris sportsman 500 dead battery
2005 polaris sportsman 500 fuse location
2005 polaris sportsman fusebox location
2007 polaris 500 ho fuse box
2007 polaris sportsman 500
2007 polaris sportsman 500 fuse box
2007 polaris sportsman 500 fuse location
2007 polaris sportsman 500 solenoid
2007 polaris sportsman 700 clicks when starting
2007 polaris sportsman no power when key on and solenoid clicks
2008 polaris sportsman 500 fuse location
fuses on polaris sportsman 500
polaris 500 sportsman dead
polaris 500 sportsman fuse box
solenoid-starter-c1100
where are the fuses on a 2007 sportsman 500 ho
where are the fuses on a500 polaris sportsman
