03-10-2010, 05:58 PM
Member #2538
had mine to the dealer because i couldnt figure it out and was told that my speedo was going bad thus not leting enough power to get to the hub coils but it cost 300 to get it fixed and he wasnt 100% sure about it i might try hooking up a toogle switch to by pass the speedo and will post if it works plowing with 2wd and tire chains for now
03-16-2010, 01:19 AM
Member #3563
Turns out the problem with my 400 was the battery, when i bought the bike it's battery wouldn't start it (had been sitting for 8months) and when i used the pull start it would go for a while and start to backfire, miss and so on, so i rigged a spare battery that i had up to it (not the correct one, just a spare 12v batt i had in my shed!) it had enough power to start the engine but still wouldn't go into 4wd in reverse. once the new battery turned up and was installed - end of problem!! the other battery didn't quite have enough juice to engage the front wheels.
02-01-2011, 09:55 PM
Member #11630
Qiuck question about 1996 Sportsman 400 - Why won't the front right wheel not engage to 4x4? This started happening tonite while plowing.
1992 polaris 250 4x4 will not go into 4x4, 1996 polaris xplorer 300 4x4 not engaging, 1996 polaris xplorer 300 wont go jnto high gear or reverse, 1996 sportsman 400 4 wheel hubs parts, 4wd broke on polarus magnum, 99 -335 polaris 4x4 front wheel hub coils, diagram for 95 polaris 425 magnum awd, magnum wont shift into 4x4, polaris 425 4x4 wont engage, polaris explorer 400 won't shift into 4x4, polaris explorer wont go in 4x4, polaris hawkeye - wont engage 4 wheel drive, polaris hawkeye 300 wont move forward or backwards, polaris ranger not going into 4x4, polaris sportsman 400 one hub wont engage, polaris sportsman 500 broken roller cage, polaris xplorer 300 wont go into all wheel drive, polaris xplorer 400 no power to 4x4, what's purpose of the fwd coil on a 1999 polaris xplorer 400, youtube polaris 300 will not go forward but will go in revarse
