05 sportsman 700 charging problems - Polaris ATV Forum
Old 04-04-2012, 09:32 AM
05polaris's Avatar
Member #24844
I am looking for any information that someone may have as to why my 05 sportsman 700 is not charging. Have brand new battery. Tesyed charging system with a multimeter while running and goes from 12.37 volts and when revived to 3500 rpms it doesn't move, stays the same. When I turn on lights and use brake lever for rear lights the voltage goes down to 12.08 v then back up to 12.28 v with everything off. Any suggestions? Voltage regulator or stator?
Old 04-04-2012, 07:59 PM
Rooftop777's Avatar
Member #24313
I had similar issue, it was my stator. I thought it was several other things until i opened the side of quad and looked at Stator that had 2 areas melted. Got rebuilt at RMstator, Polaris would charge an arm and a leg. May be other things but for me, I had the same symptoms.
2007 Polaris Sportsman 500 EFI, Black Metallic, Polaris aluminum rims, Mudlites, Warn 2500 winch, front and back bumpers.
2012 Project rebuild:2007 Polaris Sportsman 500 EFI, Red/Orange, Polaris aluminum rims, Maxxis, front and back bumpers.
2015 Project Rebuilt: 2009 Polaris Sportsman 500 EFI X2, Green Metallic, Polaris aluminum rims, Bear Claw, Polaris winch, front and back bumpers.
Old 04-06-2012, 06:34 AM
sgtski's Avatar
Member #20380
You can actually test the stator to and tell if it is good or bad. i had somewhat similar issue and also ended up replacing my stator. word of caution though... the first stator i bought came from RMSator and although it was cheap, it was also junk. i didnt read all the bad reviews on it until after the fact. in the end, i spent about $360 on new polaris stator. this one came with all connectors already in place and ended up being plug and play-- no splicing.... my suggestion, test the sator, make sure you grounds are good, then buy oem or at least avoid rm stator...
Old 07-09-2012, 08:52 AM
xispaki's Avatar
Member #14442
Here (Portugal) they charge about 700 euros (920 USD, more or less) for a new OEM stator!
JESUS F****G CHRIST!!!!
Polaris 700 EFI, with regular wheels, regular suspension, regular seat...and so on! NOW, WITH 2 EXTRA LIGHTS
CHECK IT OUT!!
2002 polaris sportsman 700 charging problems
2002 polaris sportsman 700 not charging
2005 polaris 700 not charging
battery doesn't charge on 2005 polaris ranger 700
polaris 700 charging issue
polaris ranger 700 charging problems
polaris sportsman 700 charging system
polaris sportsman 700 stator test
polaris sportsman charging problems
charging systems problems jonny Site Issues & Suggestions 1 03-20-2012 04:12 PM
Sportsman over charging Dawdyservices ATV Repair and Maintenance 4 01-21-2012 06:55 PM
96 sportsman 500 not charging Bamper Polaris Sportsman 0 12-27-2011 01:44 PM
'04 700 SP Battery Charging Problems mtnrider700 Polaris Sportsman 8 12-20-2011 09:29 AM
94 sportsman 400 not charging hairy32 ATV Repair and Maintenance 3 04-08-2010 03:49 PM
