02-05-2010, 04:08 AM
Member #2953
Thanks. I'm on the last page that has the jumper photos. I have that file by way of .pdf also, which is a little better since I can zoom in on the pictures a bit, but they're still black and white. I searched this morning, again, for a key-on 12v lead coming from somewhere up high and can't really find anything not already being used.
The three red wires in the bundle, though are key-on 12v, so I may end up tapping into that if I can't find the right wire.
02-05-2010, 05:57 PM
Member #2953
Follow up
I think I figured out what the problem was. I believe my winch is powered from what would normally be the wire I would be looking for. I think the terminal was changed out to a flat spade type and now powers that motor, so I didn't recognize a lead that would fit the jumper supplied in the kit. I left it alone and put a new spade terminal on the end of the supplied jumper and got my 12v key-on power from the three red wire bundle I mentioned earlier in the post. Problem solved, engine fired right up. All wires are tied down and it's back together just in time for this snow storm we are getting tonight.
02-06-2010, 08:45 PM
Member #3015
Snowdrift.........could you email me the pdf of the instructions? I bought the same kit but my kit is missing the jumpers and the instructions!
yrr3@hotmail.com
Todd
02-08-2010, 06:28 AM
Member #2953
Emailed.
02-08-2010, 12:05 PM
Member #3049
If possible I would like both the pdf file and the kit part number. I have an 02 rancher with a problem in CDI to female plug connection that the dealer has not been able to help me with.
02-08-2010, 12:06 PM
Member #3049
no more e-mails
Reason: Getting unsollisited e-mails
02-08-2010, 12:15 PM
Member #2953
Emailed
02-09-2010, 06:17 AM
Member #3015
Many thanks to SnowDrift who was gracious enough to send a photo of his sportsman and the .pdf of the instructions.
Any one can email me for them and I will send them to you as I cant figure out how to post them here..
02-14-2010, 05:56 AM
Member #3049
Thanks SnowDrift
After much searching at several parts places online I found one that had a CDI kit for my commercial duty Ranger 2x4.
2202602 ignition kit, 2202602 installation, 2202602 kit, 2202602 kokusan, 2202602 polaris, 2202602 red wire, ignition replacement kit update #2202602, kokusan 2202602, part number 2202602, polaris 2202602, polaris 2202602 kit, polaris 700 ignition upgrade, polaris ignition kit 2202602, polaris ignition update, polaris kit 2202602, polaris part #2202602, polaris part number 2202602, polaris update kit 2202602, polsris ignition upgrade installation, update kit #2202602
