No power to 500 HO - Polaris ATV Forum
post #1 of 3 (permalink) Old 02-02-2010, 02:50 PM Thread Starter
jollym0n's Avatar
No power to 500 HO
2008 polaris 500 ho. There is no power when I turn the key. Initially, this happened and I traced it down to a broken wire (red, power lead coming off the ignition switch). I spliced that wire and everything was working fine. However, I decided to fix some broken headlight wiring before putting it all back together. Once I was was done with that, I now have no power when I turn the key. Checked fuses and the 20a MAIN fuse was blown. Replaced it with a good one and disconnected the headlight wiring I had just repaired (expecting a short there). Still no power. Rechecked the fuses and they are fine. There are three square relays (two 20a, one 50a) amidst this wiring. What do these do? Could it be one of them and how do I test them? Is there another inline fuse somewhere? With the key on, I do read 12v on the red power lead exiting the ignition switch, but read nothing at the fuse panel. Thanks in advance.
jollym0n is offline
post #2 of 3 (permalink) Old 02-02-2010, 04:23 PM
First off, welcome to the forums!
Bruce! is offline
post #3 of 3 (permalink) Old 02-02-2010, 06:50 PM Thread Starter
jollym0n's Avatar
Thanks Bruce!
I reseated all fuses and "off/on'd" the kill switch; then got power back. Thought I did that a couple times, but evidently didn't do a good enough job. I reconnected everything and started it up. It ran about ten seconds, then blew the MAIN 20 fuse again and that is where it sits as I am out of fuses.
I am not sure what caused the ignition wire to break, it did not appear to be rubbing against anything. There were two other wires that had exposed copper but were not broke. I taped those up, but wonder if there are more and that is my problem. Unfortunately, that may mean a new wiring harness (which I am told is $300). Is there an "easy" way to determine what is causing the short / overload? I wonder about the power outlet in the light housing and will disconnect that.
jollym0n is offline
