Old 04-23-2012, 12:44 PM
defleppardsg's Avatar
Member #22390
2012 400HO - occasionally shuts off out of nowhere
Twice, over the last 3 months I've owned this quad, i'll be driving, and it'll just shut off on me.... It has started right back up no problem both times. Just weird...
I'm not an expert on carburators, but is this something that can occasionally happen? Or does this suggest that there's something wrong somewhere?
2012 400HO
Polaris 2500lb winch
Polaris front/rear bumpers
Polaris hand & thumb warmers
Relay 3-headlight mod
25" Bighorn 2.0's
Old 04-23-2012, 12:54 PM
fishhooker's Avatar
Member #23647
When it shuts off is it like shutting the key off, instantly off? Or does it sputter and cough then die?
"The Tractor" 1994 Yamaha TW200 Dual Sport
Old 04-23-2012, 12:56 PM
Member #22390
Uhh it dies pretty quick. I feel like I notice its going to turn off like a second before it does.. so maybe it hesitates for just a sec and then dies.
2012 400HO
25" Bighorn 2.0's
Old 04-23-2012, 04:01 PM
markl's Avatar
Member #24559
I had a similar problem while trail riding. Turned out the keychain was hitting the tank and would shutoff the ignition. My solution was to trim the keychain so it would not contact the tank when turn the handlebars.
2012 Sportsman 850XP EPS Sunset Red
Pure Polaris Deluxe Front & Rear Brush Guard
Ricochet Aluminum A-Arm Guards
Pure Polaris Front Lock-N-Ride Storage Box
Polaris 3500# Winch
Old 04-23-2012, 05:05 PM
bgirard420's Avatar
Member #11494
I'm with Mark, if you have a keychain get rid of it. Other things that top the list of mystery stalls: ETC maladjustment, kill switch malfunction, loose battery connections/weak battery, bad gas, fuel pump failure, carb issues, water in spark plug boot.
2013 Polaris XP 850 HO LE EPS
  • Pure Polaris hand guards
  • Polaris L&R rear box
  • Ricochet Ultimate Armor (black)
  • ATV GURU F&R Cobra Brush Guards
2010 Polaris 500 HO
Old 04-23-2012, 06:05 PM
gtsum2's Avatar
Member #23200
key chain?
Old 04-24-2012, 03:18 AM
Member #22390
i do have a keychain but i know that the key wasnt pulled to the off position when it happened. It just a small dealer keychain, couldnt really catch on anything..
2012 400HO
25" Bighorn 2.0's
Old 04-26-2012, 05:14 PM
markl's Avatar
Member #24559
I also had the dealer key chain. It would catch when I turned the handlebars. Just a thought.
Polaris 3500# Winch
Old 04-26-2012, 05:21 PM
jordaman17's Avatar
Member #13240
the key can still be on the on position, the key chain only has to move it back so far to shut it off then the ignition just flicks back to the on position. happened to me.
5140km 2008 Polaris Sportsman 500 Ho, Polaris Hand & Thumb warmers, RotoPax 4 Gallon Fuel Pack, Custom Made Rear Bumper, PowerMadd Hand Guards, Polaris Rear Work Lights, Ricochet Ultimate Armor, Modified Stock Muffler, Polaris 3500lb Winch, Rear Rack Extender, Super Atv 2" lift kit, Polaris Brush Guard, 3 Headlight Mod, Uni Air Filter, EPI 'patv1' primary clutch spring. All up on Interco Swamplites! Maintenance is the key to a never ending happiness
Check out my youtube channel! ---> http://www.youtube.com/user/mudsling...ew=0&flow=grid
Old 04-26-2012, 05:36 PM
markl's Avatar
Member #24559
jordaman17- exactly what happened to me. I replaced it with florescent yellow cloth material. (in case the key falls out) Perfect!
Polaris 3500# Winch
2004 polaris 400 just shuts off
2004 polaris sportsman 400 shuts off battery flashes relay
2008 polaris 400 ho no spark
2010 polaris 850 while riding shuts off
2012 polaris 400 ho chains
atv shuts off
atv turns off
how fast is a 2012 polaris 400ho
polaris 400 ho fuel pump no fire
polaris 850 sportsman key shuts off
polaris atv just shutting off?
polaris shuts off everytime i drive it
polaris sportsman 400 ho cuts off
when a fourwheeler key turns off
who repairs yamaha atv in duthess county, ny
x2 shuts off j0yride40 ATV Repair and Maintenance 9 04-10-2012 03:29 PM
2012 sportsman 500ho vs 400ho al_z71 ATV General Discussion 19 03-21-2012 04:11 AM
Shuts down when put in reverse Oldun Polaris Trail Boss 0 08-10-2011 02:34 PM
Gets wet and shuts down!!! n2mudn ATV Repair and Maintenance 4 02-20-2011 11:18 AM
08 400ho radiator LtDangle ATV Repair and Maintenance 0 12-08-2010 06:27 AM
