  #21 (permalink)
Old 10-08-2010, 06:07 AM
denseleit's Avatar
Member #2441
Originally Posted by FishAlaska View Post
My dealer has told me the noise is the slack in the drive train. They all do it they claim. They did however order me the Engine Braking System (EBS) clutch kit and think that this will keep tension on the belt during decent until the RPM is low enough and keep the slack out of the drive train. EBS is NOT standard on these machines, you have to order it as an option. They got it for me free of charge. I hope it helps this aweful clanking sound. What do you all think? My buddy has the 800 X2 with the EBS and he doesn't notice any clanking. Will see if it works.
My 08 800 has EBS and still has the noise, although mabye not as loud as yours is/was but still noticible. My 15yr old daughter rides it now and I ride my xp so it doesn't bother me anymore lol. But I believe it is just slack in the gears and nothing to worry about IMO.
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
  #22 (permalink)
Old 10-08-2010, 06:37 AM
FishAlaska's Avatar
Member #7476
You have a valid point. The slack is always going to be there and may get worse with wear. It may also vary from machine to machine. Mine is so slight now with the EBS that it makes it tolerable. Without it, oh my it was horrific. You could hear me coming down a hill a mile away. Clackity clank click click. Now I don't even need to use brakes much.
2010 Polaris 800 EFI Sportsman, I guess they call it. Factory EBS installed, 14" ITP SS312 Wheels, 26X9X14 ITP Terra Cross fronts and 26X11X14 ITP Terra Cross rears, Big Bike hand and thumb warmer, Polaris Lock and Ride rear box w/side bags and back rest, American Trails low center front cargo bag, Polaris Tank Bag, 2500 Polaris Winch, Polaris front and rear brush guards, Polaris front and rear rack extenders, 1 inch drop receiver and 2 inch ball. Ran out of things to buy!
  #23 (permalink)
Old 11-26-2010, 08:15 PM
wacked's Avatar
Member #9046
I just bought a 2010 800 Sportsman, it too has clanking noise after you cut the throttle going at speed. This is happening on a snow covered road I might add. It seems like the wheel/transmission speed being greater than the engine speed will cause this. My unit does not have the
engine braking system on it. Our friend from Alaska has had good luck I believe... I wonder what the kit will cost in Canada??? Anybody know??
  #24 (permalink)
Old 05-02-2011, 07:51 PM
cadpat's Avatar
Member #9679
Send a message via Skype™ to cadpat
Just thought I would add to the thread for any one that is interested. I have a 2011 Sportsman 400HO. I have the same noise if I'm braking hard or slowing down. I have 2300KMs on the quad with no problems and it seems to be fine. I checked my drain plug on the trany and there's no wear marks on it like others have noted.
2011 Polaris Sportsman 400 H.O.
Viper 3000lbs winch w/KFI mount
Heated hand grips
Uni Air Filter
3 Headlight Mod Relay Type http://www.polarisatvforums.com/foru...ete-video.html
  #25 (permalink)
Old 05-23-2011, 10:34 AM
jeremy_450's Avatar
Member #15321
Hey guys, I have a 2010 800 Mine does the same thing since it was new..took it back to the dealer they said it is normal. they said that when they first came out with the 800 they had problems with them breaking gears because of the high torque so they hardend the gears and they had to put more slack in the gears becuase of this so that is why you hear the noise
Tags
drive, shaft
2008 f350 noise on decel
800 sportsman popping noise
850 xp front drive shaft play
drive shaft rattel polaris sportsman 500
ebs releasing noise polaris sportsman
noise on driver side 06 f350 on decel
noise when i release the gas
polaris 2010 sportsman 800 driveshaft poping noise
polaris 500 drive shaft noise
polaris 800 drive shaft noise
polaris atv noise when off gas
polaris drive shaft noise
polaris driveshaft noise
polaris sportsman 500 ebs popping sound
polaris sportsman 500 should there be back lash in the transmission
polaris sportsman 850 rear prop shaft slop
polaris sportsman drive shaft noise
polaris sportsman transmission gear lash
releasing gas without soun
sportsman800 noise decelerating
