05-06-2012, 03:12 PM
Member #26015
sputtering problem
I just got this used 2006 Polaris 450 sportsman it has 365 miles and 60 hours in this machine. the engine idles good but when i put it into gear and start drive the throttle goes good until it gets around 5000 rpm then it starts sputtering like its not getting gas.when i have it in park i can rev the motor up and it doesn't sputter.only starts when I'm at high speeds the sputtering start. It was running fine until i drained the gas and put high grade of gas in it and sea foam. the part guy told me to clean calibrator run 2 oz per gallon first then only run 1oz then after of the sea foam . also im also having a problem with the battery icon keeps flashing on the screen and the speed needle flashes. when i turn the head light on it goes away. i als  o installed a new battery problem didn't resolve
05-06-2012, 05:39 PM
05-06-2012, 08:10 PM
Member #23274
Is this unit carbed or F.I.? Kinda sounds like it's hitting the rev limiter or running out of fuel. Anyone know the rev limits on these???
05-06-2012, 08:28 PM
Member #26015
It has a carbrator
05-06-2012, 10:08 PM
Member #23274
Ok, the main jet is eigther to small or partially plugged. If you replace it go two steps larger. There is a number stamped on the jet. And use the Sea Foam!
2006 polaris 4 wheeler -dies when you give throttle, 2010 rzr 800 sputtering like its not getting gas, 2011 polaris scrambler sputter half throttle, 4 wheeler sputters at higher speeds, atv sputtering at high speed, kfx 90 atv sputtering troubleshooting, polaris 90 sportsman sputters, polaris 90 sputtering no choke, polaris ranger 700 will spit and sputter in gear, polaris sportsman sputter, quad high speed sputter, sputtering polaris rzr, what makes four wheelers spit and sputter 800 polaris, what will make a polaris rzr sputter at higher speeds, why does my atv sputter when i give it gas
