05-09-2012, 05:26 PM
Member #23274
You asked for opinion's so I just gave mine. Maybe next time say you just want to hear from the others that think this is so cool and I'll leave your post alone as I will this one from here on out.
05-09-2012, 05:50 PM
Member #9482
Welcome to Facebook - Log In, Sign Up or Learn More check these guys out there axles are proving to be awesome. 250 bucks lifetime warranty. Cant beat a deal like that. Not trying to sell just passing it along.
2in highlifter lift
Racked Radiator
30in moto monster
14in diesels
Hmf Swamp series xl
05-10-2012, 04:09 AM
Member #17395
I have a 2007 SP800 and added a HL 2" lift, EPI HD springs and 28" Mudlites and my left rear axle inner CV broke just driving around no mudding.
05-10-2012, 04:35 AM
Member #25355
Thanks for all the input guys, decided to take the lift off I am not that aggressive of a rider. Just will keep the swamp lites 28" maybe add the dalton blue orange spring and call it good..
07-05-2012, 11:50 AM
Member #22212
lift kits
im having the same problem i put a 2 inch lift on the front and 1.5 on the back the back is fine. i broke the front inner on the left side so i replaced it thinking it was old my brand new one came today put it in and 10 mins later broke the inner one again. so im cutting 1/2 inch off the front lift to see if it helps any
07-05-2012, 12:03 PM
Member #25355
I just took mine off all together, rode the other day and no more problems...
07-05-2012, 12:10 PM
Member #22212
now im stuck waiting for the parts store tto get me another one in its place i might just get bigger tires and do aaway with the lift im undecided
07-05-2012, 12:23 PM
Member #23274
Hehehehe!!!!
07-06-2012, 04:33 AM
Member #22643
Granted Reno gets a little too much starch in his skivvies now and then, but stop to think a bit before you all jump on him. The Axles installed from the factory were designed to run very reliably for quite a long time within their designed operating angle range. When you add any lift, you are running at the designed maximum angle or even slightly above the safe angle, depending on how much lift you install. Then when you add taller tires, you are compounding the stress. I'm with Reno on this, don't overextend beyond the designed capabilities unless you are ready to pay to compensate.
Fred
I have my Flame Retardant Suit on.
09 800 sportsman lift, 2 inch front lift polaris sportsman, 2 inch lift polaris sportsman 800, 2007 sportsman 800 lift kit, 2012 polaris sportsman 800 front lift, 2012 polaris sportsman 800 lifted, best axles for sportsman 800, do you need aftermarket axles on a sportsman 800 if you put a 2in lift, high lifter pro series lift for 2012 polaris sportsman 800, how go is a axil on a 2007 polaris 800 with 29 inch wheels, how hard is a lift kit install on a sportsman 800, is a sportsman 700 front cv shaft same as sportsman 800, polaris sportsman 800 2in lift kit, polaris sportsman 800 8 inch lift, will i need bigger axles with a 3 lift on sportsman 800
