Clutch Problem - Polaris ATV Forum
post #1 of 6 (permalink) Old 05-10-2012, 02:47 PM Thread Starter
98sportsman's Avatar
Clutch Problem
hey I have a 1998 sportsman 500 and my belt is always ridding on the inside of the primary clutch witch is making it creep away and can't shift out of gear with out shutting the bike off. Help me please.I have tried moving the engine, putting a shim behind secondary clutch and even tried an old belt all to get the same exact results.
98sportsman is offline
post #2 of 6 (permalink) Old 05-10-2012, 03:10 PM
Bruce! is offline
post #3 of 6 (permalink) Old 05-10-2012, 10:04 PM
RENOBADBOY's Avatar
Idle set to high??? Have you removed the cover and looked at the clutch while it's running? Can you take some pic's or a video?? Does the belt ride high in the driven clutch(rear) Is the drive clutch (front) retracted at idle? (The sliding part of the clutch up against the center bolt)
RENOBADBOY is offline
post #4 of 6 (permalink) Old 05-11-2012, 06:11 PM Thread Starter
It has nothing to do with the idle, I do believe that it is 2 washers/spacers on my primary clutch on each side of the engine brake. So I'm gonna try that and hopefully it will fix my problem
post #5 of 6 (permalink) Old 05-12-2012, 03:18 PM
Kevcules's Avatar
I had the same problem with my 01 sportsman. After replacing the front motor mount and trying move the engine a little to the left , I added a second washer to the secondary clutch which was 1/16" wider than the old washer and works perfectly. (I now have 2 washers , one is a little bigger than what was already there) The bike will creep if the belt doesn't ride in the CENTER of the primary clutch pulley.
Kevin
Kevcules is offline
post #6 of 6 (permalink) Old 05-19-2012, 06:27 AM Thread Starter
Hey found the problem for my bike creeping away and the belt ridding on the inside off the primary sheave. there is a brass washer and a composit washer on each side of the one way clutch in the primary for engine brake. the washer wears out and stops the one way clutch from turning causing the belt not to release properly and ridding on the inside of the sheave.
thanks for all the ideas.
525 clutch problem xruppay22 Polaris Outlaw 4 12-31-2011 06:01 PM
Clutch problem jlahood ATV Repair and Maintenance 7 11-16-2011 05:16 AM
clutch problem gumbo ATV General Discussion 5 10-24-2011 07:54 AM
Clutch noise problem Kodiak450 ATV Repair and Maintenance 3 04-20-2011 01:07 PM
clutch or throttle problem? justin ATV Repair and Maintenance 3 05-31-2010 09:45 AM
