Radiator cleaning - Polaris ATV Forum
post #1 of 6 (permalink) Old 05-12-2012, 02:11 PM Thread Starter
SledRacer112's Avatar
Radiator cleaning
Thought I'd share this...
Last season I rode all season with no issues overheating...toward the end of the season we did a big ride that involved more mud then usual. I ended up overheating during that ride and it was terrible because we were hours from home...I'd ride 10 minutes stop for 15 to cool down then start again. After that ride I hosed out my radiator from the front and rear the best I could, and never over heated again that season.
Now next weekend we are getting ready to go on a big ride...cover the same areas that we did last season when I overheated. So I figured I would be ready this year by tearing my radiator out, really cleaning it and I'm going to try straight water with water wetter this year instead of the 50/50 coolant.
Yesterday I started to tear the radiator out. Got the fan out and couldn't believe my eyes. Even with srpaying the radiator out with a hose multiple times, going to the car wash once and using the pressure washer to clean the radiator...it was still CAKED with mud! Check out the pictures!
Needless to say, I took the radiator completely out, soaked it in a bucket and hosed it down repeatedly.
Just goes to show that running a hose in there really doesn't do the job when you get into some heavy mud!
ID:	7252   Click image for larger version
ID:	7253   Click image for larger version
ID:	7254   Click image for larger version
Mine - 2007 Sportsman 800 - 27" Mudlites on SS rims, HID's, 3 headlight mod w/ relay, 2500lb winch, 4 gal rotopax, PowerMadd hand guards
Wife's - 2010 Polaris Sportsman 500 HO - HID's, 3 headlight mod w/relay and 2500lb winch, WES rear seat & kimpex foot pegs, 4 gal rotopax
SledRacer112 is offline
post #2 of 6 (permalink) Old 05-12-2012, 02:55 PM
KICKER431's Avatar
Yup, those would be the parts that the fan shroud covers and keeps you from getting at with the hose. Luckily having the center real clean helps prevent over-heating. But you are right. pullin git is the only way to ensure it is clean. Enjoy your ride without the overheating this year.
completely stock FOR NOW
26" Maxxis Bighorn 2.0
KICKER431 is offline
post #3 of 6 (permalink) Old 05-13-2012, 06:17 AM
macka's Avatar
straight water is bad. The coolant is not only formulated to lower the freezing point, but it also raises the boiling point. It also protects the passages from scaling as most people just use tap water instead of distilled. In my experience, I see more overheating in machines where guys cheap out and use only water, because it boils at 212 or less depending on the mineral content and elevation, and pressure inside the closed loop system.
Went for my routine checkup today and everything seemed to be going fine until he stuck his index finger up my butt! Do you think I should change dentists?
macka is offline
post #4 of 6 (permalink) Old 05-13-2012, 08:33 AM
CVCOBRA1's Avatar
Agreed, straight water, even with "water wetter" is a bad idea. Put your 50/50 mix in there.
CVCOBRA1 is offline
post #5 of 6 (permalink) Old 05-13-2012, 08:41 AM
SMP63's Avatar
And using "DISTILLED" water is very important when mixing with cloolant!!!!!!!!!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
SMP63 is offline
post #6 of 6 (permalink) Old 05-13-2012, 11:05 AM Thread Starter
Interesting. I had planned to run distilled water and water wetter. I've seen on other forums, like the Hi Lifter forums where people were running distilled water and water wetter and it was making machines run cooler. Some were only 4 or 5 degrees cooler..others 10 to 15 degrees.
Cleaning XP Plastic microracer25 ATV Visual & Body Modifications 4 03-30-2012 04:40 PM
ATV Cleaning Wildsteer ATV New Members 4 03-27-2012 04:07 PM
Engine Cleaning wolf ATV General Discussion 3 03-26-2012 09:54 AM
RAD Cleaning Twitch2146 ATV Repair and Maintenance 1 03-05-2012 08:16 AM
Cleaning Tips SLxp550 ATV Repair and Maintenance 10 08-10-2010 05:40 PM
