  #11 (permalink)
Old 06-27-2012, 12:34 AM
PLUMMER's Avatar
Member #4033
If the water pump is bad or there is a leak elsewhere, remember the cooling system is pressurized and it will force water thru the rings into the chamber. Or I should say it can. Does or did your overflow spill over ever? if not the excess pressure might have filled up yer case.... I'm prayin for better luck for you, especially after all you've done to that machine.
2001 SPORTSMAN 500 HO REMINGTON SPECIAL EDITION
FOOD PLOTTER, WORKHORSE, TRAIL BREAKING HUNTING MACHINE
CLUTCH WORK SET TO "TRACTOR"
  #12 (permalink)
Old 07-01-2012, 09:06 PM
muddbone's Avatar
Member #19279
If you run into the water in oil issue again and dont feel like changing the oil five times, get a half gallon of diesel fuel and run it through the engine. Than will remove all the water and save you a bunch of money
  #13 (permalink)
Old 07-02-2012, 01:03 PM
Diesel man 03's Avatar
Member #7294
Glad you got it.
  #14 (permalink)
Old 07-02-2012, 02:04 PM
bigredrider's Avatar
Member #15048
Send a message via ICQ to bigredrider
If I sink mine in the water before changing the oil I put a half can of seafoan in the crankcase run it for 2 or 3 min change the oil, seafoam helps take the water out better. I can change my one time after a dip sometimes I have to do it twice but that stuff works good for me just my thought
600 polaris water in oil
atv get water out with diesel
get water out of oil on atv
how to get warer out of oil in a polaris
how to get water out of an atv engine
how to get water out of atv
how to get water out of oil in car
how to get water out of the oil in a polaris ranger
how to get wter put of oil
sportsman has waterin the oil
water in my atv
water in oil sportsman
what causes polaris 400 atv get water in cylinder
what would cause the water in a radiator on a atv to mix with the oil
with water in the oil will it cause the engine to knock?
Water in oil modlite52 ATV Repair and Maintenance 7 11-17-2011 06:26 PM
water...oil? bad!!! Rabbit ATV Repair and Maintenance 11 11-16-2011 03:22 PM
Water in gas!!!!!!!!!!!! lod666ftw Polaris XP 12 10-26-2011 04:20 PM
Under Water polaris50007 Polaris Sportsman 8 09-29-2011 10:19 AM
water and oil seals for water pump replacement fred398 ATV Repair and Maintenance 1 01-20-2011 04:41 PM
