Front axle removal - Polaris ATV Forum
post #1 of 5 (permalink) Old 07-18-2012, 06:50 AM Thread Starter
Hosstile's Avatar
Front axle removal
Hey there,
I have an 07 sportsman 500 and Ive been trying to remove one of the front CV axles. I have removed it from the strut so that the axle is just dangling there. Its my understanding that the whole axle should just pull out of the differential. Are they generally stuck in there or am I missing something? Tips, tricks? Also there is suppose to be a retaining clip on the outer joint inside the boot that I cant see. Should the outer Joint just slip off the spline or is there a retaining clip that I don't see?
thanks,
Brendan
Hosstile is offline
post #2 of 5 (permalink) Old 07-18-2012, 07:40 AM
DevinDDR's Avatar
I have a 2012 not sure if they are the same but if you just have it hanging there you should be able to give it a good pull and a slight twist and it should come out. It's prob going to take a little elbow greese though. Pull hard and twist at the same time.
DevinDDR is offline
post #3 of 5 (permalink) Old 07-18-2012, 07:54 AM
JimmyC's Avatar
Had a friend of mine with the same problem after hours of trying to pull it out with no success he went to auto zone and ended up renting and using a large dent puller connected to the axle and pulled it out with a couple good pulls.
I've seen some crazy suggestions to include laying the ATV on its side and hanging it from the rafters to get the axle out. Check out youtube you'll there's a lot of info on there too.
2011 Polaris XP 850 X2 LE, Polaris 3500HD Winch, Polaris Deluxe Front Brush Guard, ATV Guru Rear Bumper, Front Lock box, SS312 Wheels and 26" Zilla tires w/slime, Kolpin Fender Flares, Ricochet Ultimate Armor Kit,
2012 Polaris XP 550 EPS, Magnetic Metallic, Polaris 3500HD Winch, Polaris Deluxe Front and Rear Brush Guard, Front Lock box
2011 Polaris Phoenix 200 Red/Black
JimmyC is offline
post #4 of 5 (permalink) Old 07-18-2012, 11:30 AM Thread Starter
Hosstile's Avatar
Ive been tugging on it pretty good and it isnt budging
Hosstile is offline
post #5 of 5 (permalink) Old 07-18-2012, 12:11 PM
DevinDDR's Avatar
Man I don't know then, I'd maybe try what jimmyc suggested, I've never had a problem with one being stuck in there, could be due to the fact that mine is newer, but I still wouldn't think it should be that hard.
DevinDDR is offline
front cv axle removal mbeal ATV New Members 8 12-29-2013 07:57 AM
01 sportsman front outer cv joint removal from axle eye_guysd Polaris ATV How-Tos 12 06-02-2012 05:28 AM
Front 4x4 Wheel Bearing/Axle/Clutch Removal VIDEO carralo1 ATV Repair and Maintenance 0 02-13-2012 11:38 AM
cv axle removal brenthattaway ATV Repair and Maintenance 2 12-04-2011 06:01 PM
2009 Sportsman 800 front axle removal idler8 ATV Repair and Maintenance 0 09-18-2011 10:56 AM
