Audio Tube Build - Polaris ATV Forum
Old 07-18-2012, 06:33 PM
87ttopstang's Avatar
Member #23491
Audio Tube Build
Thought I'd share my audio tube build. I was going to purchase an audio tube, but when I looked into purchasing one, I determined I could build one with better components for less money.
I decided to build a three speaker tube, that fits on my front rack perfectly. I have an 04 Sportsman 700 EFI. The rack itself is approximately 31" wide. The two 90 degree elbows and one T fitting fit perfectly. Kinda lucked out with that. I didn't need to cut the fittings at all.
Here is what I started with. I used my chop saw to cut the straight pipe to make the couplers.
Couplers dry test fitted into 90 degree elbows.
One 90 degree elbow glued together and screwed to the T fitting.
Pieces glued in for mounting speakers.
Pieces of 2x6 cut to fit inside tube to mount amp on.
Second piece dry test fitted and casting marks sanded off. Waiting for amp and speakers to arrive. Should be here by tomorrow.
Old 07-18-2012, 07:12 PM
skizmo's Avatar
Member #13773
Thanks for sharing..I will be watching for the rest of the build...
Old 07-18-2012, 07:19 PM
stspower's Avatar
Member #28170
I've seen alot of these but I just learned alot more on how to make them. Looking good and Im looking forward to the finished product. Can you give us more info on the speakers and amps please? Are you using marine speakers or regular car audio? I've thought about doing this same set up but putting a sub in as the third speaker since my wife likes to listen to a little rap every now and then.
Old 07-19-2012, 04:29 AM
Member #23491
I was thinking of going that route as well. Two 6.5" speakers on the outside and one 6.5" sub in the middle but after planning it out, I decided not to. My reasoning was cost. The price of a marine 6.5" sub is quite high. I wanted to keep costs down.
I decided to go with three Pyle PLMRS62 200 Watt 6.5'' 2 Way Marine Speakers and a Pyle PLMRMP3A 4 Channel Waterproof MP3/ Ipod Marine Power Amplifier. It is capable of 4x200 watts max @ 4 Ohms or 4x100 watts RMS @ 4 Ohms. It has a direct Ipod hook up as well. My Ipod will be providing the music. The amp should power the speakers nicely.
Old 07-19-2012, 04:42 AM
highmark's Avatar
Member #9483
Nice build so far. Looking forward to seeing how the rest of this turns out.
Jay
98 Banshee (sold)
08 Polaris 500 X2 (sold)
02 400ex (The Unicorn Build)
Old 07-19-2012, 05:56 AM
IGotSoldJunk's Avatar
Member #27440
thats sweet im interested to see how it turns out aswell.
98 Polaris Sportsman 500
97 Polaris Sportsman 500
84 Honda Big Red 200 E
87 Big Bear 350 4x4
94 Suburban 4x4 350ci
06 Durango Hemi
88 Starion Big turbo ect
13 Mazda 3
Old 07-22-2012, 08:20 PM
Member #23491
Found some time on the weekend to finish off the audio tube.
Here is the amplifier I went with. It is compact and fairly powerful. I am very happy with the cost as well.
Amp mounted on the cut pieces of 2x6 and wiring started.
Amp mounted inside tube. Lots of room.
Second end of tube attached and all wiring finished. The hole you see is for the external volume control for the amp.
Underneath of tube where power wires exit. Rubber grommet was used and I used silicone to ensure no water would seep in.
Ready for paint. I used Valspar Plastic paint.
Tube painted and the center speaker mounted. You can see the external volume control and the fiberglass poly fill I used to give the speakers a better sound.
The final product. I hooked it up to give it a test run and this thing sounds GREAT!!! It far exceeds my expectations. I am very pleased with the outcome. The speaker grills match the color scheme on my ATV as well.
Once I have it mounted to my front rack, I will take a video and upload it to YouTube for those of you that want to hear what it sounds like. I am very pleased.
Old 07-22-2012, 08:58 PM
stspower's Avatar
Member #28170
That thing is badass. Looks like you took your time and did it right the first time.
Old 07-23-2012, 03:51 AM
highmark's Avatar
Member #9483
Great build and thanks for the update. How did you mount the speakers to the PVC?
Jay
98 Banshee (sold)
Old 07-23-2012, 05:00 AM
Member #23491
Drilled holes for the screws, then simply screwed the speakers to the PVC. The inner green pipe in the fittings gives enough area to screw the speakers to.
atv audio tube
atv audio tube build
atv audio tube plans
atv radio tube
atv speaker tube build
build atv speaker tube
diy atv audio tube
homemade atv audio tube
how to build an audio tube
how to build atv audio tube
how to build atv speaker tube
how to build audio tube
audio tube help matzy11 ATV Visual & Body Modifications 7 02-26-2013 02:08 PM
How much for re-build? 30calpal ATV General Discussion 5 06-07-2012 01:49 AM
Audio Tube Advice thole15 ATV Visual & Body Modifications 9 05-02-2012 06:46 PM
brand new in box, never used Polaris RZR JL Audio Slam Pack Sub Stereo maxjll ATV Parts for Sale 2 05-18-2011 12:11 PM
Homemade Audio Pipe rebelrider ATV Visual & Body Modifications 15 11-07-2010 09:26 AM
