Polaris sportsman 90 problems - Polaris ATV Forum
Old 08-08-2012, 08:30 PM
jackjoseph's Avatar
Member #28854
I can't get my ATV to keep running unless I hold in the throttle. Can I adjust throttle or carb?
Old 08-08-2012, 09:45 PM
aknawful's Avatar
Member #18402
it's #6 in the diagram, goes straight into the middle of the carb. screw in to raise idle.
2006 Polaris 90 Predator A06KA09CA Parts, 2006 Polaris 90 Predator A06KA09CA OEM Parts - BikeBandit.com
if it's not that #7 may be dirty.
1998 Honda 300
2005 Predator 50
2012 Outlander 1000XT. Elka Stage 4s, Rox 2", Bearclaw HTRs.
Old 08-08-2012, 09:49 PM
Rooskey's Avatar
Member #22134
I have looked at both of your threads. Let me start by asking is this your personal fourwheeler and how old are you. Would like to try and help out but just want to know the basics. I think we all here on the forum may need a little more info. With this particular problem it seems like your choke may need some adjustment. Also how old is your fourwheeler..
2012 Sportsman 550 EPS Bronze Mist
2010 Sportsman 550 X2 Sage Green
2014 Sportsman 90 Sage Green
2006 Grizzly 125 Green
Old 08-09-2012, 04:40 AM
jackjoseph's Avatar
Member #28854
It is a 2008 that I have for my son. When I took the carb off, the choke seems to work pretty well. I think #7 should be clean b/c I have taken it all apart. I like the idea of adjusting #6. I have it screwed all the way out thinking more gas would get in. So maybe I need to screw it in. I will try that tonight. Thanks!
Old 08-09-2012, 07:53 AM
aknawful's Avatar
Member #18402
#6 is the idle. screw it in and the bike should run. if it's all the way out then thats the problem. it is basically a wedge that lifts the slide up giving more throttle at idle.
1998 Honda 300
2005 Predator 50
Old 08-10-2012, 01:19 PM
jackjoseph's Avatar
Member #28854
new light bulb in taillight works. Must have been bulbs. Screwed in idle screw yesterday and idle worked. Went back today and now I can't get anything to start even with starter spray. Pulled out the plug and I can't see any spark. Looked up and saw 1 of 4 wires solder loose from a white rectangle. Made sure it is touching. Still no spark.
Old 08-10-2012, 02:25 PM
aknawful's Avatar
Member #18402
#14 is a resistor. probably need a new one. it may have burnt the fuse when it broke and why the bulbs burnt also.
2008 Polaris 90 Sportsman (A08FA09AA/AB/AC) Parts, 2008 Polaris 90 Sportsman (A08FA09AA/AB/AC) OEM Parts - BikeBandit.com
1998 Honda 300
2005 Predator 50
Old 05-15-2015, 04:52 PM
bjr's Avatar
bjr bjr is offline
Member #51563
got a sportsman 90 it will run great for about 20 minutes then will die let it sit for five or so it will start back up run again for 20 minutes then die need help
Old 05-15-2015, 05:18 PM
M_Quick's Avatar
Member #13816
check vent tube in gas cap, sounds like a vapor lock.
2001 Polaris Scrambler 500 4x4 Stolen @ MJ USA
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2006 Polaris Phoenix 200
2008 Honda Trx700xx
2003 poaris 90 sportsman carb adjustment
2006 polaris sportsman 90 problems
carburetor polaris sportsman 90
polaris 90 problems
polaris 90 troubleshooting
polaris sportsman 90 carburetor problems
polaris sportsman 90 issues
polaris sportsman 90 review
polaris sportsman 90 troubleshooting
reviews for 2012 polaris sportsman 90
sportsman 90 carb adjustment
polaris sportsman 700 problems please help? marcusboudreaux Polaris Sportsman 1 05-30-2011 04:28 PM
06 polaris sportsman 700 4x4 problems Cowboyffa84 ATV Repair and Maintenance 2 05-03-2011 09:17 AM
problems with polaris sportsman 550xp rcarrillo Polaris Sportsman 3 01-30-2011 11:09 AM
Two problems with my 02 polaris sportsman 400!!!! chillmouser ATV General Discussion 10 01-01-2011 06:57 PM
polaris sportsman awd problems atvman2010 ATV Repair and Maintenance 5 12-17-2010 08:32 PM
